20 Most Recent LG Wm0642hw Front Load Washer 4.0 Cu. Ft. Factory Refurbished For Usa-17653 Questions & Answers
BLOCKAGE SOMEWHERE IN PUMP OR HOSE LINES
LG Wm0642hw... | Answered on Mar 30, 2015
call in a qualify technician you know or ask a friend to introduce one to u..
LG Wm0642hw... | Answered on Nov 23, 2014
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG WM Washing... | Answered on Oct 29, 2018
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
LG WM Washing... | Answered on Dec 27, 2017
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
LG WM Washing... | Answered on Apr 25, 2017
http://www.lg.com/au/support/support-product/lg-WT-H9556
LG WM Washing... | Answered on Mar 29, 2017
There is no need to raise the water level. all modern washers automatically add the amount of water needed to wash the amount of clothes that you put in, I could explain how, but it will put you to sleep. rest assured these machines pretty much look after themselves. I would be more interested to know why you think it needs more water, are you having rinsing issues? wash quality issues?
LG WM Washing... | Answered on Oct 18, 2016
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel.
Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
LG WM Washing... | Answered on Aug 15, 2016
If you wish to get some details; check the site linked here. Pull up older posts........
http://electro-medical.blogspot.com/
LG WM Washing... | Answered on Jun 12, 2016
take the back off
see if the water pump making that noise or is broken
should look something like this one
LG WM Washing... | Answered on May 18, 2016
run a wire thru it no doubt it is plugged with crud
LG WM Washing... | Answered on May 02, 2016
There probably isn't one. If you are certain power is getting to the machine, there may have been control failure.
LG WM Washing... | Answered on Apr 25, 2016
2 possible causes
the water solenoid control valve is split in the diaphragm and not stopping the water
the small hose from the base of the tub to the level control pressure unit is split or disconnected or the pressure unit has failed and is not activating the water control valve
LG WM Washing... | Answered on Mar 25, 2016
Take out the soap drawer and clean the fabric softner compartment. This happens when there is residues left. And it gets clogged up.
LG WM Washing... | Answered on Feb 17, 2016
The obvious question is how do you know that it is soap? What washing machine is it? The biggest problem with most washing machines is that people use too much soap to begin with. I would go to a store and get a new t-shirt or something. Run the machine with nothing in it. Then put the shirt in and run it again without adding any soap. When it is done check the shirt for soap. There could be a build up on the inside of the drum.
LG WM Washing... | Answered on Feb 13, 2016
LG Wm0642hw Front Load Washer 4.0 Cu. Ft. Factory Refurbished For Usa-17653 Logo
2 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
loud humming noise when water drains
  • Washing Machines
