20 Most Recent LG / WM1355HW Questions & Answers
LG washer won't turn on
WASHER WILL NOT START: Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary. Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch.. If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start. Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself. Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly. Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on. The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings. By the way my advice is free cuz God is good! All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced Lastly CONTROL BOARD If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures. 13962915-0ibogqi43422e0jrk2ickvgv-2-0.jpg 13962915-0ibogqi43422e0jrk2ickvgv-2-2.jpg 13962915-0ibogqi43422e0jrk2ickvgv-2-5.jpg 13962915-0ibogqi43422e0jrk2ickvgv-2-9.jpg 13962915-0ibogqi43422e0jrk2ickvgv-2-14.jpg 13962915-0ibogqi43422e0jrk2ickvgv-2-20.gif
5/25/2015 11:59:18 PM • LG / WM1355HW • Answered on May 25, 2015
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
Lg washing machine-wt1501c
If you wish to get some details; check the site linked here. Pull up older posts........ http://electro-medical.blogspot.com/
6/12/2016 7:02:11 PM • LG WM Washing... • Answered on Jun 12, 2016
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off see if the water pump making that noise or is broken should look something like this one 26197828-pe3l0ypp1vfpknq0mkt0qwu4-3-0.jpg
5/18/2016 9:54:37 AM • LG WM Washing... • Answered on May 18, 2016
Hi I have lg WT H550 machine when I turn on the machine the water is not stopping come into the machine what should I do water level is coming upto the top
2 possible causes the water solenoid control valve is split in the diaphragm and not stopping the water the small hose from the base of the tub to the level control pressure unit is split or disconnected or the pressure unit has failed and is not activating the water control valve
3/25/2016 7:33:57 AM • LG WM Washing... • Answered on Mar 25, 2016
My fabric softener dispenser is filled with water after a wash cycle
Take out the soap drawer and clean the fabric softner compartment. This happens when there is residues left. And it gets clogged up.
2/17/2016 6:55:13 PM • LG WM Washing... • Answered on Feb 17, 2016
2answers
Soap is not rinsing out of my clothes. It has been getting worse and worse. Even if I use a tiny bit of detergent.
The obvious question is how do you know that it is soap? What washing machine is it? The biggest problem with most washing machines is that people use too much soap to begin with. I would go to a store and get a new t-shirt or something. Run the machine with nothing in it. Then put the shirt in and run it again without adding any soap. When it is done check the shirt for soap. There could be a build up on the inside of the drum.
2/13/2016 5:42:14 AM • LG WM Washing... • Answered on Feb 13, 2016
LG / WM1355HW Logo
2 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
lg washer won 39 t turn
  • Washing Machines
