20 Most Recent
Sony VAIO PCV-W1 PC Desktop Questions & Answers
How to recovery sony VGC-RB34G without discs
I was not able to solve my problem. I called a mechanic who came and wipe out every thing and even my recovery could not work and I was asking what I could buy to restore my recovery disc.
C'ant see videos in you tube. cpu working 100%
You need to go to MSconfig and turn off all programs you do not need running when booting the computer. Run scandisc and defrag. Make sure that you have a lot of RAM memory. Scan for viruses and malware.
The repair man has delited everything from my
it is possible to recover corrupt or deleted files, but that requires specialized software. If your "repair man" formatted and or deleted the partitions on your hard drive... well then you are out of luck and have to start your reinstall from scratch.However most recovery files are stored in a separate partition on your hard drive. If you are lucky, that partition is still there and you simply have to tell your recovery cd where that partition is.
Bought used computer no disc I wont to clean it
if the computer is a sony vaio start the computer and try F8 or F10 repeatedly until the the ADVANCED BOOT OPTIONS screen appearsif that doesn't work you may have to contact sony vaio for recovery disks
I don't have audio and
Make sure that audio is enabled in the BIOS.
Check to see if it displayed in the device manager and that it is enabled, as this will prevent you from installing the driver.
It is also possible that the device is defective and you will need to replace it.
I hope this helped.
Good luck and have a fantastic day.
Can this computer be wireless
Natively not, but you can install a wireless card or use a stick to be able to connect a wireless network.It will not go faster if you post many times the same problem.
Wireless
Can anybody help me with my krybord semes too be
The VAIO Hardware Diagnostics utility can be used to perform various
tests to ensure the computer is working properly and diagnose hardware
issues when they occur. Follow this procedure to perform a Quick Test or
Individual tests using this utility.
- Close all open programs. NOTE: If the VAIO Recovery Center application is already open, proceed with step 3.
- Open the VAIO Recovery Center application. NOTES:
- If the VAIO Hardware Diagnostics window is already open, proceed with step 4.
- The VAIO Recovery Center software can be accessed from the Start menu. Click the Start button, click the VAIO Recovery Center folder and then click VAIO Recovery Center .
- If you cannot start the operating system, the VAIO Recovery Center software can be accessed by pressing the F10 key at the BIOS screen, but all the hardware component tests may not be available.
- You
also can access the VAIO Recovery Center software by booting the
computer using the Recovery Discs. Insert Recovery Disc #1 and then
restart the computer.
- In the VAIO Recovery Center window, under Choose a program , click VAIO Hardware Diagnostics .
- In the VAIO Hardware Diagnostics , click the Start button.
- On the Quick Test tab, click the Run Test button. NOTES:
- To perform any of the individual tests available within the VAIO Hardware Diagnostics utility, click the Individual Test tab.
- The Individual Test tab is only available when the VAIO Recovery Center is started from within the operating system.
- Tests
can be run on the following components: CPU, Memory, Video, Hard Disk
Drive, CD-ROM, DVD-ROM, Network Adapter, USB, CF/PC Card, and Memory
Stick.
- The CPU, Memory, and Hard Disk Drive tests are performed
during the Quick Test. The Video and CF/PC Card tests are also
performed as part of the Quick Test when the VAIO Recovery Center is
started from the desktop.
How do I fit physicaly extra ram into my Sony
You simply must use RAM that is more per Stick, these days you can get single DIMM's 1, 2, & 4GB Modules, so that's what one must use to "Upgrade" Whatever RAM type your RAM is, simply obtain the biggest size you wish to increase to, and Plug it in, the Operating System & PPC, will automatically detect the new RAM, and configure and work automatically.
Cant find where to get
Not all laptop computers have built-in wireless capability,
but all the newest ones do.
You may need to purchase either a PCMCIA or a USB wireless-adapter, and insert the adapter into the appropriate slot, to add wireless capability.
Hi, I have quite a rare pc - a Sony PCV-W1G
It could be any number of things, most likely the power supply or motherboard. If the computer is 6 years old, you're probably better off getting a new computer than trying to troubleshoot and fix it. Other parts will start to go bad soon, including the hard drive, and you'll find yourself spending more money to keep the computer running.
Unit will not come to life - Red light on swich
Sorry you are having trouble. Without the ability to see the screen there is little you can do. If I were to attempt a repair I would take a new Hard Drive (HD) and install Windows on it. This would merely verify the rest of the unit is good. It sounds like a trip to the shop is needed here.
No sound,No Icon even
There may be several problems that may make your sound unable but i think that here it is a problem of sound driver
go there
http://www.sony.com/ and get support and download the sound driver
hope that it will be helpful &don't forget to rate
kind regards
