20 Most Recent
Sony VAIO PCG-K23 Notebook Questions & Answers
How do i unlock a sony vaio notebook. I forgot my password and dont have those old documents!!
This can be usually done by a Windows Password Tool. However, if you have already activated the Administrator on the PC (Any Brand) with Windows 7. You can try the following steps.
Generally, the logon does not have the administration account listed. So one may want to go restart the machine to the Command Prompt to enable the Command Prompt.
Restart the Machine --> Tap F8 (Advanced boot options) --> Go Save Mode With Command Prompt --> Command Prompt Window appears. Type :
1: net user Administrator /active: yes
2: shutdown -r
This would restart the machine and the Windows Logon will have the Administration account. You can login to the Administration Account and then change the password on the other account.
Also, If you do not have the the admin account activated, then you may want to get windows key from
http://www.lostwindowspassword.com/windows-password-recovery.htm
(This is a paid software).
You may get several free software's online as well.
Thanks,
Rahul a
7/16/2014 2:41:26 PM •
Sony VAIO...
Answered
on Jul 16, 2014
Boot from usb
go to bios menu and boot option boot external drive enable and change the boot order that's all
12/5/2013 8:28:00 AM •
Sony VAIO...
Answered
on Dec 05, 2013
Help please
Try booting up into Windows Safe Mode (F8 during bootup or watch for an option for Boot Menu) and see if you're having the same issue.
10/20/2013 2:19:01 PM •
Sony VAIO...
Answered
on Oct 20, 2013
Laptop screen divided
Try connecting the laptop to an external monitor if it works well. Be a problem in the laptop screen
5/18/2013 1:22:40 PM •
Sony VAIO...
Answered
on May 18, 2013
Motherboard vgn
Which is what?No display on internal monitor of laptop?Squiggly lines or pink screen, or vertical or horizontal lines?What is the problem?Also is it a Sony VAIO PCG-K23 Notebook PC?Post back in a Comment.Regards,joecoolvette
4/30/2013 11:43:00 PM •
Sony VAIO...
Answered
on Apr 30, 2013
Is there a software that is associated with my
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
Disconnect AC adapter
Shutdown laptop
Remove laptop battery
Connect AC adapter
Power on laptop
Click the Startup Menu
Type Device and select Device Manager
Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
Shutdown laptop
Insert laptop battery
Connect AC adapter
Power on laptop
If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
Hope to have been of assistance,
Thanks.
9/14/2011 11:15:50 AM •
Sony VAIO...
Answered
on Sep 14, 2011
