20 Most Recent Danby DWM17WDB 22" Portable Top Load Washer with 11 lbs. Capacity, 4 Water Level Settings, 8 Wash Questions & Answers
I can't get the cold water tubes to attach to my
the machine should come with an adaptor that screws or to your faucset to attach your water line from washer-a hardware store might be able to help you find one-cheers Denny
10/26/2013 1:01:34 AM • Danby DWM17WDB... • Answered on Oct 26, 2013
Black bits/gunk/ mold/ smells awful!
It does have a filter, but it is out of stock. https://www.reliableparts.ca/product/inv_11431896 Drop a gallon of bleach into it. Put it on hot wash, and before it pumps out, turn it off and leave it full for a couple of days full. Then carry on with the cycle. It should loosen all the debris. https://www.google.com/search?q=danby+model+dwm99w+filter ..
3/18/2023 3:52:09 PM • Danby Washing... • Answered on Mar 18, 2023
2answers
Danby DWM99W washer wouldn't go into spin cycle unless turn timer a notch by hand then completes the cycles
Most washers of my experience have at least one programme that stops the wash, leaving water in the tub until the programmer is advanced a notch by hand when it will pump out and enter the rinse/spin cycles. I suggest you reread the instructions just to be clear whether there is a fault.
5/6/2020 8:28:39 PM • Danby Washing... • Answered on May 06, 2020
Danby Washing Machine Model DWM5500W tub fills motor will not start
check to see if 'closed lid switch' is working.
8/7/2019 5:22:47 AM • Danby Washing... • Answered on Aug 07, 2019
I have a Danby portable washer, DWM17WDB the agitator won't turn while its washing, but will turn if its draining or spinning out. Please help
Maybe it’s a dual action agitator where top turns independently of the bottom. Gears inside agitator may be stripped out.
10/15/2018 1:56:22 PM • Danby Washing... • Answered on Oct 15, 2018
Danby flame adjust
Since you are dealing with a gas appliance and any gas appliance could blow I strongly suggest contact your gas company and have them come out and help you with this.
2/4/2018 2:35:53 PM • Danby Washing... • Answered on Feb 04, 2018
Danby DWM17WDB 22" Portable Top Load Washer with 11 lbs. Capacity, 4 Water Level Settings, 8 Wash Logo
5 questions posted
Top Danby Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
David Spradling
David Spradling
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Danby Washing Machines
Most Popular Question
bangs while spin cycle
  • Washing Machines
