20 Most Recent
Neff B1421 Electric Single Oven Questions & Answers
Oven is beeping and showing f1
Hello Charlie,The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
Neff oven door gets hot
cooling ventilator fan has failed or jammed with grease this is not the fan at the back of the oven!
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Removal of interior oven light
Most require a simple 1/4" nut driver to remove 2 screws that hold the glass housing over the bulb. Then just unscrew the bulb and install new one.
