20 Most Recent
Hotpoint Belt for CTD00P, CTD40, CTD80, CTD85 Tumble Dryers Questions & Answers
Heating element will not heat , the element is ok
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.html
No power to myctd80 dryer
if i remember rite ctd40 has three stats over heater 1 has pin hole in top push needle in hole to reset it and take needle out then try ive done this on sum
Timer counts down too quickly
Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
Faulty control board hotpoint ctd85
You can remove the panel and check for fault in the connectors and the line to the display, use a hair dryer to warm and dispel any moisture on the board and panel. If there is no result then the panel has to be replaced. To remove click :
control panel
After fitting a new time to a hotpoint CDT00
Sometimes even one connection can make the circuit non functionable and so it can be due to a wrong connection. I request that you check once again and logically check the lines to go in order to start the cycle, INLET, cut off from the water level sensor, Start motor, stop and drain, spin and rinse, fill water and then for final dry and drain pump.Check for all leads to be correct, check if the stepper motor works in circuit to move forward after the main power is switched. Check this link for tips:
washing machine
Hotpoint VTDOO dryer works but timer does not move and no reverse
sounds like you may have a timer with the contacts sticking closed at certian intervals. or a bad pcb check visual inspection of PCB look for burns or bulges, on the diodes or capcitors, Ihave in the past taken timers apart and fixed sticking contacts by sanding with emery cloth.
Hotpoint Aquarius dishwasher DWF34S/42 no power - possible fuse blown
Based on your description, it sounds like there was a short circuit in the dishwasher which caused the fuse to blow and the burning smell. It is possible that the burnt connection you are seeing is related to the short circuit.
If you have experience with electrical repairs, you can try to identify and replace the burnt connection. However, if you are not comfortable with electrical work, it is recommended that you seek the assistance of a qualified technician to avoid any potential safety hazards.
In any case, before attempting any repairs, make sure that the dishwasher is disconnected from the power source and that all safety precautions are taken.
Hotpoint TCFS93B is the motor starting to fail or ?
It is possible that the motor in your Hotpoint TCFS93B tumble dryer is beginning to fail if it is experiencing difficulty starting up and exhibiting similar symptoms to a failing capacitor. However, without more information or further diagnosis by a qualified technician, it is not possible to accurately determine the cause of the issue
