20 Most Recent
Neff V4380X0 Front Load Washer / Dryer Questions & Answers
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
E - 01, NEFF WASHER DRYER
there is to your right an bottom of washer a small door open it an you should see a small switch that you can take a small long screwdrive pess it down an door will unlock ok
NEFF V4380 WASHER MANUAL
You should be able to find one on line or call the makers customer services and they may send you one
Bra wire
you can take off the rubber around the drum and then using a torch find the wire an get it out or if you have a magnet use that.
