20 Most Recent
Roper Washer Timer Control 3351734D A E B Questions & Answers
CAN a 4 prong plug be change to fit a 3 prong so it will fit my 3 prong receptical
Hi Anthony:
A 4 prong plug is intended to handle 220/240 volt and also 110.
It has:
- Red and Black - 110 each 220 total
- White (neutral)
- Green (ground)
You will need to shut off the circuit breaker for your receptacly and then determine what power supply you have available.
You MAY be able to change your receptacle to handle your appliance.
I would NOT change the plug on your appliance as it needs both the 110 and 220 functions.
If you are not ABSOLUTELY SURE what you are doing, get an electrician. Not doing it right could start a fire or present the danger of electrical shock. WHICH HAS THE POTENTIAL OF KILLING SOMEONE.
Cheers.
I have a Roper washing machine. Is it normal that she keeps the same water to rinse?
No, it should pump out and add fresh water, agitate, spin, add water again, agitate, and then pump out for final spin. Check the pump and filter area for obstructions. Having said that, the logic board should halt everything and error out if there is no pump out. Try disconnecting from the wall socket for 15 minutes, and then plug back in.
My Roper top loading washing machine goes thru the first wash cycle, empties the water then stops. It does not move on to the rinse cycle.
If your Roper top loading washing machine is stuck on the first wash cycle, you're not alone! It's a common problem that can be caused by a few different things. First, check to make sure the lid is closed properly. If it is, then you may need to check the timer, the water level switch, or the motor. If you're not sure how to do this, it's best to call a professional. Trying to fix it yourself could end up costing you more in the long run. But don't worry, you'll be back to washing your clothes in no time! Just remember, when it comes to washing machines, it's better to be safe than sorry.
ROPER WASHER PULLEY SYSTEM WON'T SPIN OR DRAIN
There are a few potential causes for your Roper washer not spinning or draining:
- Drive belt: If the drive belt is broken or slipping, it could prevent the tub from spinning. Check the belt for any signs of damage or wear, and make sure it is properly tensioned.
- Lid switch: Even though you said the lid switch is ok, it's still worth checking it again as it is responsible for ensuring that the washer will not spin or drain unless the lid is closed.
- Motor coupler: The motor coupler connects the motor to the transmission and can wear out over time. If it has failed, the washer won't spin or agitate. Check the coupler for any signs of wear or damage.
- Drain pump: A clogged drain pump or pump motor failure can prevent the washer from draining. Check the pump and clean out any debris that may be blocking it.
- Control board: The control board could also be a potential culprit, especially if the washer is not completing cycles correctly. Check the board for any signs of damage or malfunction.
- Transmission: If none of the above solutions work, there may be an issue with the transmission. This will require a professional repair.
I hope this helps you diagnose and fix the issue with your Roper washer.
There are a few things you can try if your Roper washer is not going through the full cycle because it is only filling with a small amount of water:
- Check the supply of water: Check to see that all of the water supply valves are open and that the hoses are free of kinks and obstructions. The washer may slowly fill due to low water pressure.
- Check the valve at the inlet: The washer may not properly fill due to a clogged or damaged inlet valve. The valve may need to be replaced in this scenario.
- Verify the pressure switch by: The pressure switch tells the control board to move the cycle forward by sensing the tub's water level. It's possible that the control board won't be notified to start the next cycle if the pressure switch is broken.
- Examine the control panel: The control board may be defective and need to be replaced if none of the aforementioned steps resolve the issue.
Troubeshooting Roper Washing machine
Humming is normally indicative of a failed Start/Run Capacitor, but the fact you get nothing from it, leads me to believe it is a control board issue as well. Due the cost, call for Service so that you get the correct diagnosis.
