20 Most Recent Panasonic Toughbook T2 Notebook Questions & Answers
I need Panasonic CF-T2
All drivers for all Panasonic Toughbooks, including BIOS updates are available from the following website: Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK... Good Luck to you and Regards from: Richard, Montreal Based Panasonic Canada Toughbook Authorized Dealer since 1989.
2/5/2018 4:13:17 AM • Panasonic... • Answered on Feb 05, 2018
0answers
How do i scroll up and down on a panasonic
The verticle scroll can be done in two ways. Using the mouse to point over the scroll bar. Left click and hold the left mouse button and drag your finger up or down across the touch pad. The second way is to trace a circle around the outside of the touch pad.
I hope this information was helpful. Let me know if you need any further clarification.
I have attached a link to the panasonic manual download page for your toughbook. You can download the operating instructions booklet to see more information about your toughbook.
Brian
http://www.panasonic.com/business/toughbook/computer-support-download-manuals.asp
1/9/2011 12:43:26 AM • Panasonic... • Answered on Jan 09, 2011
0answers
Well i felt my laptop
The lighting tube broke - you will need to open the screen case to access and replace it.
10/18/2010 3:43:26 PM • Panasonic... • Answered on Oct 18, 2010
How to update for SD reader
You don't.
You have to a seperate HC reader.
Had same problem.
4/4/2010 6:46:14 PM • Panasonic... • Answered on Apr 04, 2010
I have a TouchScreen CF T2 panasonic and enabling
it's you wireless lan driver. install the correct one from panasonic's support website and you should be good to go.
2/24/2010 4:41:14 PM • Panasonic... • Answered on Feb 24, 2010
Missing system file
Yer with an external hard drive or a flash drive stick, copy the OS cd on to the drive then set the bios to boot from USB or OTHER DEVICE.
1/16/2010 4:57:11 AM • Panasonic... • Answered on Jan 16, 2010
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
10/4/2009 4:23:16 PM • Panasonic... • Answered on Oct 04, 2009
2answers
Power off
That is because of the invention of power saving modes, where a single touch puts it in sleep mode and a 4+ second touch turns it off.
Check the bios to see if there is an option under the power saving section. You may be able to change this function to suit you.
6/10/2009 4:51:40 PM • Panasonic... • Answered on Jun 10, 2009
Can't get onto internet because of error message.
Hi there
Try a different explorer instead, Mozilla Firefox 3.0 is an excellent browser.
Good luck and thanks for using Fixya!!
2/12/2009 3:03:09 AM • Panasonic... • Answered on Feb 12, 2009
White screen
White screen usually means the display itself (not the inverter, but the panel) has gone bad.Could go in and check the ribbon cable connection to the mainboard and see what happens. More than likely you need to replace the panel. Sorry.
4/23/2007 1:05:08 AM • Panasonic... • Answered on Apr 23, 2007
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows: Hold down the "CTRL" and the "ALT" keys and while holding down these two keys press the "UP Arrow" key and then release all three keys. This will reset the screen so it is right side up instead of upside down. Good Luck and regards from: Richard, Authorized Panasonic Canada Toughbook Dealer since 1989. P.S. The arrow keys look like this: The up arrow is the one on the top arrowkeys-wizlq2ugugduqihzx2y1x4lj-1-0.jpg
4/6/2018 5:40:18 PM • Panasonic... • Answered on Apr 06, 2018
How do I turn on the keyboard lights on the Panasonic CF-53. I don't know the function.
I'm not sure if yours is the same layout as the CF-53 I use. But my F12 button has a picture of a button with light on it. I use FN-F12 to adjust the brightness of the keyboard. Mine goes through 5 brightness levels before returning to off and starting over.
12/3/2016 2:49:23 AM • Panasonic... • Answered on Dec 03, 2016
Panasonic cf-y4 driver
The VGA or "Video Driver" for the Panasonic Toughbook CFY4 can be found at: http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html Remember to choose your operating system and then click on the "Download Now" button located on the right side. Good Luck! Regards, Richard - Montreal Based Panasonic Canada Toughbook Dealer since 1989
2/18/2016 5:54:02 AM • Panasonic... • Answered on Feb 18, 2016
F11 key
From two different websites: The same answer 1) "F-11 seems to have been an emergency hot key for police use" The website: http://forum.notebookreview.com/threads/rubber-illuminated-kb-cf-29.239110/ 2) "The red F11 can be programed to report through police dispach an officer is in trouble. This key only works with Special software used by Law Enforcement." The website: https://groups.google.com/forum/#!topic/toughbook/J__ssDTCm_0 Both these guys gave the same opinion and both seem very knowledgeable. Good Luck! Regards, Richard - Montreal Based Panasonic Canada Toughbook Dealer since 1989
2/18/2016 5:13:06 AM • Panasonic... • Answered on Feb 18, 2016
Screen stays dark
On ALL Panasonic Toughbook Models, if the screen stays dark I would shut-off the Toughbook and connect an external monitor to the VGA port (15-pin female connector), which is usually BLUE in color. Make sure the monitor is ON first, then turn ON the Toughbook. If the monitor comes on then your problem is the backlight or possibly the inverter of the screen. If no image is shown on the external monitor and the screen stays dark and you cannot hear any startup (ie. Windows) sound, then your video card may be defective. Very few Toughbooks fail this way since they are normally very very relaible but it can happen. Good Luck Regards, Richard - Montreal Based Panasonic Canada Toughbook Authorized Dealer since 1989
2/18/2016 4:50:23 AM • Panasonic... • Answered on Feb 18, 2016
0answers
Panasonic Toughbook T2 Notebook Logo
18 questions posted
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Toughbook Panasonic
  • Toughbook Panasonic
Most Popular Question
need panasonic cf t2
  • Computers & Internet
