20 Most Recent HP Compaq Presario sr1010z PC Desktop Questions & Answers
The green light flashing is a diagnostic LED light, telling you there is a power failure.
More specifically a bad Power Supply.
Weak voltage power rail.
The Power Supply used in a Compaq Presario SR1010Z desktop computer, is a 300 Watt unit, and is an ATX form factor.
[ATX form factor for a Power Supply, denotes the size of the Power Supply case, and the shape.
It is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
The ATX form factor for a Power Supply is used in over 90 percent of the personal computers out there, and is as readily available as the air we breathe]
Usually, HP uses one of three generic Power Supply manufacturers.
1) Bestec
2) Delta
3) HiPro
All are low quality Power Supply manufacturers.
This is HP Support, and the main menu page for the Compaq Presario SR1010Z desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/product?product=1146324&lc=en&cc=us&dlc=en&submit.y=7&submit.x=6&lang=en&cc=us
If you click on Manuals, then on Upgrading and Servicing Guide on the following page, there are instructions on how to open your computer case.
This is instructions on how to replace a Power Supply, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&cc=us&lc=en&dlc=en&product=3548196
(It's for a Pavilion a6230n desktop computer, but after you open the computer case of your Compaq Presario SR1010Z, the instructions are the same)
What Power Supply would I recommend?
There are 100's to chose from.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276575&CatId=1078
Chosen because;
1) Maximum wattage is rated at 450 Watts.
A computer ONLY uses the power it needs, and NO more.
Wouldn't matter if you had a 10,000 Watt power supply, (No such thing. An exaggeration), if your computer only needs 100 Watts, it would only use 100 Watts.
(Surfing the internet typically uses 100 watts)
2) Has all the power cables you'll need, and more. Tie up the power cables you do not need. (Use plastic ties, Not wire, or bread wrapper ties)
3) 24 Amperes (24A) on the 12 volt power rail.
4) 135mm cooling fan.
The cooling fan on the Power Supply you have now is 80mm.
A larger fan turns slower. Produces as much air as a smaller fan, (Or more), but makes less noise.
Less wear on the fan's bearings also.
5) Is an ATX form factor Power Supply.
6) It's 80 percent efficient, compared to the 60 percent efficient Power Supply you have now.
(That is, if it was working)
HP Compaq... | Answered on Sep 16, 2010
You'll need to reset the security settings. Go to this Microsoft page for step by step instructions: http://support.microsoft.com/?id=313222#appliesto
HP Compaq... | Answered on Mar 13, 2009
Try using the Office 2003 removal tool. Just download the Office 2003 Editions Resource Kit at this link. It's called ork.exe:
http://www.microsoft.com/office/orkarchive/2003ddl.htm
After it's installed followed these directions:
To locate the tool, click the Start button, point to Programs, point to Microsoft Office, point to Microsoft Office Tools, point to Microsoft Office Resource Kit, and then click Removal Wizard.
Then follow the on screen instructions that will walk you through the removal. After Office is completely removed, restart and try to reinstall.
Hope this helps!
HP Compaq... | Answered on Mar 09, 2009
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
HP Presario... | Answered on Jun 21, 2017
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
HP Presario... | Answered on Jan 26, 2017
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck
G
HP Presario... | Answered on Jul 30, 2014
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply"
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
HP Presario... | Answered on May 13, 2014
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
HP Presario... | Answered on Mar 04, 2014
Ask The People Who Work At HP To Find Out !
HP Presario... | Answered on Feb 18, 2014
if u r listening extra vibration sound with actual sound just change speakers
HP Presario... | Answered on Oct 28, 2013
try using a can of Air Duster on the bottom of CP57 where your fan is located to clean out the heatsink allowing your system to stay on and figure out the issue.
HP Presario... | Answered on Sep 23, 2013
no proberly not,you should never do so.
i understand you wan't to add moore memory (RAM)
windows 32x can only handle max 4 GB.windows 64x 8-12 GB.
invest in some new memory (RAM) that's best.
HP Presario... | Answered on Apr 25, 2013
If you boot to safe mode is it the same? What proceeded this issue? Any damage? Updates? Overheating?
HP Presario... | Answered on Apr 04, 2013
HP Compaq Presario sr1010z PC Desktop Logo
4 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
green light in rear flashing part up
  • Computers & Internet
