20 Most Recent
Magic Chef Built-In Dishwasher Questions & Answers
Dishwasher doesn t dry
A simple solution would be to not select Heat Dry if you have that option on your machine. When the washing cycle is complete, open the door partially (4 to 6 inches) to allow the hot water vapors to escape.
Evaporation will dry the dishes in the lower section and the warm dishes can be returned to your cabinet.
Glasses, etc., from the upper section can be removed and stored.
In the remaining space on the upper level. Cups that may have some water remaining in the depressions at the bottom of the cup are turned horizontally in the basket so the water from the depressions can drain. Some minimal wiping may be necessary prior to storage.
Not only have we solved the drying problem we have added some humidity to the air; do not have to worry about a non-functional switch and reduced our electric bill as well.
As a side note, once all of the above has been completed we never close the door completely but leave it an inch or two from a complete close; this will not compress the door gaskets and will add to their service life.
Hope this helps!
Dishwasher not draining
Check the very bottom strainer in the dishwasher first. Clean it out and then (as long as the pump is good) the washer will drain.
No receptacle for rinse agent
U can buy a soap with rinse agent in it already. I think one brand that offers this Finish. I don't know anyway of adding a receptacle to an older washer.
Magic chef du4000v
You can install it on the cold water line. The dishwasher has its own heating element to heat the water.
