20 Most Recent
HP ScanJet 2300C Flatbed Scanner Questions & Answers
On pressing scan button an
This means that the scanner is experiencing an error. The best solution is to reinstall the drivers for this scanner using the disk that came with the unit. I trust you have already made sure that the USB connector is connected to your computer. Try all USB ports on your computer, front ones and rear ones.
If the problem persists see the HP website and click their support/downloads button and find the latest driver download for your model of scanner. New drivers may work this problem out.
Take care!
damnor01
Scanned image comes out all black
The scanner has a locking device for transport. If it has inadvertently gotten flipped it will cause this issue. Look for the little green or blue tab labeled "Lock" "Unlock" making sure it is unlocked.
Can 2300c work with 19v power supply?
According to this site: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bus05611&lang=en&cc=us&contentType=SupportFAQ&prodSeriesId=73500&prodTypeId=15179 , it supports power from 9V to maximum 12V. 19V seems to be too much.
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
2300c scanner just installed but
Try uninstalling and reinstalling the drivers for the printer on to the computer.. Also make sure that the ink cartridges are inserted properly and that no errors are appearing on the printer.
