20 Most Recent
HP ScanJet 2200C Flatbed Scanner Questions & Answers
I need a driver for
You can find drivers for HP 2200C Scanjet scanner for Win 7 and 8 from
www.hamrick.com. Its working with watermark in free edition otherwise you have to buy the licence.RegardsMukesh
MY SCANNER IS HP SCANJET
Hello:
Try going to Hp solutions website and download the updated drivers for windows 7. Usually the drivers come with windows operating system. But you may need a new driver for the unit to work correctly.
Hp2200c scanner not working on
It appears that HP lo longer supports drivers for Vista or Windows 7 support for this model scanner.
Normally they monitor downloads and make decisions on the number of downloads and cut of accordingly due to usage and other factors. It may be possible for them to supply drivers for your scanner in future or at a request from you.
I do not recommend using after product driver sites, as I have found them not to work as well or not at all or stop working, plus many have malware attached and other problems.
I have provided a link below to the HP site for your model scanner, please click on the link or copy and paste into your browser for opening HP's support page for other drivers.
Good Luck
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=28416&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=28415
I can not save multiple
You cannot save multiple pages as a single file using a flatbed scanner.
Create
a WORD document then paste each images on a page, save the Word
document and you can
also create a PDF of the Word document.
Where could I find a
Sorry , but there is none: not only that the support for this scanner ended in 2004 when the last XP SP2 driver was issued , but there has never been one for 64 bit, only for 32 bit. VueScan supports your scanner because they have created their own generic driver and it's embedded in their program if you really want to use that scanner you would have to buy it.
But the free option is to install XP Mode in your Windows 7 and in it to install the scanner.
Hp scanjet2200c has no driver for windows 7
If there is no driver for Windows 7 sometimes the older Windows drivers will work in emulation mode. Try it to find out. If it doesn't work with the older drivers available online, then I am afraid that the scanner may have to be considered end of life or obsolete, unfortunately.
You could use it with a computer that has the older operating system, but alas, some devices are not supported ultimately, by the present Windows 7 Operating system.
I've experienced this with some 'upgraded' computers that are just a a few years old. They lose functionality on a certain fraction or percentage of hardware devices that are 'built in' to the computer, like the touch pad for instance on my Acer Aspire 3680 series computer. It quit working, and upon researching the drivers for the device, found no Windows 7 device driver that worked. So, one has to just accept that some products are no longer supported under Windows 7 32 bit, or 64 bit especially.
Good luck on finding a driver that will work with your device.
From where can i optain
That one does not support windows 7 but you can install the driver for xp and it might work first uninstal all drivers for the scanner do this go to systems and hardware remove all the old drivers and then install the driver that is most recent like xp or vista,
Good Luck
Chris Thrash
B52Computers
