20 Most Recent
HP ScanJet 4600 Flatbed Scanner Questions & Answers
Glass is broken. How do I replace the glass
HP does not sell the glass part for this scanner separately. Therefore replacing it yourself or having it repaired it not possible.
You will need to purchase a new scanner - the same one is available at www.dolphininc.net for $195.
My scanner will no longer copy after I updated to
go to the manufacturers website and download the latest vista drivers, also you can find out if it is even compatible with vista. last call customer support..make sure you ask for a spanish speaking person if you want somebody that speaks english. hp has the worst customer support that i ever dealt with
Scanner stopped in the middle of a scan
Although I can not be sure without testing it, the most common problem with this type of issue is that the power supply adapter has failed. According to the manual (posted at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00215714/c00215714.pdf) this scanner has an external power adapter. Since you indicate that the scanners light does not come on, I would be inclined to believe that power adapter needs to be replaced. However, before you go and buy a new one, I would suggest you get the current adapter tested with a volt meter to determine if it is outputting the correct voltage and amperage.
If you discover that the power adapter has failed, you may be able to simply replace it in order to get the scanner up and running again. However please take note that depending on what part of the adapter circuit failed, its failure could possible have also damaged the scanner's internal circuits. However, if you find after testing that the adapter is outputting the correct voltage and amperage, then the problem would most likely be a scanner board circuitry failure.
How to increase scanning speed in hp scanjet g2410
Install the drivers for it from the HP website. Other software for it should be there as well. As to scanning speed, setting it to scan at lower resolutions can speed scanning. Scanning for color is slower than scanning for Black and White, FYI.
What is meant by PDF in used in scanning?
If you are asking about the "SCAN TO PDF" button, it allows the scanner to create a Portable Document Format (PDF) file. PDF files are files that can be viewed with the free Adobe Reader software. The PDF format files are easy to store on your computer and easy to share. PDF files can have many pages. Image files, like JPG, can only hold one page per file.
If you use PDF files, make sure you only get the reader software from Adobe.com.
Adobe Reader Download Free PDF viewer for Windows Mac OS Android
