20 Most Recent HP 4570C Flatbed Scanner Questions & Answers
0answers
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
5/6/2012 12:22:02 AM • HP 4570C Flatbed... • Answered on May 06, 2012
I've lost my transformer for
24 volts at approx 1.2 Amps
7/17/2011 8:15:49 PM • HP 4570C Flatbed... • Answered on Jul 17, 2011
2answers
I have a hp4570c scanner
For that you need to install windows 7 compatible driver.
Click here
Click on above link and download driver for vista it is compatible with win7.
Let me know if you need further assistance.
Thanks for using FixYa.
3/17/2011 5:05:07 PM • HP 4570C Flatbed... • Answered on Mar 17, 2011
Trying to connect to an
If you are under Windows 7 , it's because HP doesn't produce anymore drivers for your unit beyond VISTA .
Download the latest driver available from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=77368&
and try running your scanner with it . If you don't succeed , try in compatibility mode .
If it still doesn't work please don't blame me , blame HP .
Best regards .
2/2/2011 6:26:54 PM • HP 4570C Flatbed... • Answered on Feb 02, 2011
2answers
Loaded HP Scanjet 4570c software correctly but
My I know your Operating System?
12/14/2010 7:01:31 PM • HP 4570C Flatbed... • Answered on Dec 14, 2010
Scans are very dark and cannot be adjusted with
What software are you using to adjust? Even office picture manager will do it.
8/23/2010 7:02:41 PM • HP 4570C Flatbed... • Answered on Aug 23, 2010
I have a HP scanner
I believe the drivers for the scanner is what is making it not recognize your mac. I think you did not install the drivers (CD) for the scanner, or the driver (CD) you have is not for Mac operating system.
Go to the Hp link below, select Mac operating system (Choose Mac OS X or Mac OS 9, these are the two available). Then proceed for the driver download.
After downloading the drivers, install it on your Mac and try connecting the scanner thereafter.
Give the above solution a trial, as it should solve the problem.
Good luck.
4/28/2010 6:33:47 PM • HP 4570C Flatbed... • Answered on Apr 28, 2010
The lamp is out.
try http://www.ebay.com
you will get one there and it sure comes with instructions on fixing.
Good look
12/26/2009 10:12:48 PM • HP 4570C Flatbed... • Answered on Dec 26, 2009
Light bar stops too soon
I assume you are using this with a computer. One thing comes to mind that relates to software. You should be able to do a preview scan of the whole scanner bed, then move the frame to the area you want to scan only, sort of like cropping the picture. If those crop borders are set to less than the whole document, you will get this kind of scan.
Now if that isn't the problem, the scanner likely has a electronic issue unless the scanner has had a nasty fall. If you want to really explore deep and don't mind if it doesn't work afterwards, turn the scanner off and unplug the power. Open it up just enough to access the optical unit and see if it will move the entire length of the scanner without binding where you experience the end of the scan. Go rather slowly and gently so you don't strip the toothed belt if it has one. You will feel a wierd sensation and some resistance as you move it along which has to do with the stepper motor and that's normal. If that works, it's likely it failed on it's own. If it binds where the scan ends, you'll have to investigate whether it's due to a rusty rail (hope not!) or some other obstruction.
7/28/2009 10:57:11 PM • HP 4570C Flatbed... • Answered on Jul 28, 2009
HP 4570C flatbed scanner. Windows XP. USB
Go to the control panel and look under cameras and scanners.Then look under events.You should be able to figure it out from there.
7/22/2009 7:39:47 PM • HP 4570C Flatbed... • Answered on Jul 22, 2009
I have an hp scanjet
Could possibly be broken down or faulty scanner.
read this page and go over the steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bps05270&lc=en&dlc=en&cc=us&lang=en&rule=23276&product=77368
Also try to completely uninstall the machine from your system, first by uninstalling the software, start -> control panel -> uninstall programs or "add or remove programs". find the scanner shoftware and related and uninstall them.
then open the device manager by right clicking on my computer you should find it from your desktop or from the start menu, right click and select Manage.
on the management window on the left side select device manager, now on the right side, find imaging devices, right click on your scanner and select uninstall, if you have the option also check uninstall driver software.
make sure there is no trace of the scanner in device manager and then unplug the scanner.
Restart the computer.
now with the device uninstall and the programs uninstalled. download the latest software for it from
install the softwares and plug in the scanner when asked or after the setup.
the scanner should get installed in few minutes after which you should be able to scan, if not then restart the computer.
Try scanning anything and see if the problem is still there or not?
Thank you,
Ekse
6/22/2009 1:13:55 PM • HP 4570C Flatbed... • Answered on Jun 22, 2009
My HP flatbed Scanner 1500 all in one does not scan
If you are using Windows Vista OS, then you are not likely to have the scanning feature functional as its version of the machine's drivers does not include scanner. Otherwise you could have succeeded in printer installation. It is recommended to install the drivers without connecting/attaching the device to the system until when prompted incase you want to re-install the software. Good luck
4/28/2009 12:09:13 PM • HP 4570C Flatbed... • Answered on Apr 28, 2009
HP 4570c scans totally black or bluish-green with vertical bars
It could be one of two things:
1) The scanner isn't registering black or white during the initialization processing depending on what color it needs to get it started.
2) The CCD unit in the scanner could be failing which could explain why it was only working briefly before getting worse.
3/22/2009 8:02:02 PM • HP 4570C Flatbed... • Answered on Mar 22, 2009
Hi, My HP 4570C scanjet
Posted by Lonu Feruz,
I have HP scanjet but unfortunately i dont have the driver CD and it is not written anywhere to show HP scan model except this number C7710A. Which driver works on type of scanjet using windows XP
1/6/2009 7:28:53 AM • HP 4570C Flatbed... • Answered on Jan 06, 2009
Scanning bar light
Do you mean the green power light? I have the same brand and a similar scanner, and the light does always stay on. I think it is a normal function of the scanner. It may not be a good idea to unplug the scanner. I am going to be a bit more research so that we can both be reassured that this is normal.
I'll get back to you.
8/16/2008 3:54:26 PM • HP 4570C Flatbed... • Answered on Aug 16, 2008
HP 4570C Flatbed Scanner Logo
Popular Tags
32 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
tma doesn 39 t work code 22
  • Office Equipment & Supplies
