20 Most Recent HP LaserJet 2420 Printer Questions & Answers
Printer says 41.3 unexpected size in tray 2. How
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
11/26/2023 1:19:58 PM • HP LaserJet 2420... • Answered on Nov 26, 2023
2answers
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
2/24/2023 9:32:06 PM • HP LaserJet 2420... • Answered on Feb 24, 2023
Hp laserjet 2420 service error 49.0665
This is either a firmware error or a memory error.
Try downloading and installing new firmware from HPs website.
Instructions are on the site.
3/15/2022 2:19:28 PM • HP LaserJet 2420... • Answered on Mar 15, 2022
HP Laserjet 2420 error 41.2
hi i found the problem in hp laserjet 2420 printer error 41.2
3/15/2022 2:18:43 PM • HP LaserJet 2420... • Answered on Mar 15, 2022
HOW DO I MAKE A
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
3/15/2022 2:17:09 PM • HP LaserJet 2420... • Answered on Mar 15, 2022
2answers
Hp laserjet 5200 the attention
This can be a number of reasons however I would be looking for a piece of paper jammed in the printer somewhere. Is the printer giving an error message or code?
If you turn the printer off, disconnect the printer cable, wait 5 minutes & then turn the printer back on, does it then power up & go to ready?
6/21/2021 1:32:06 PM • HP LaserJet 2420... • Answered on Jun 21, 2021
3answers
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
1/7/2020 6:33:45 AM • HP LaserJet 2420... • Answered on Jan 07, 2020
6answers
Standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
12/4/2019 8:31:12 PM • HP LaserJet 2420... • Answered on Dec 04, 2019
Hp 2420 prints a ''job storage status page'' after each print job
If you have your software driver or print job set to save your print jobs to the printer and your printer does not support this, you will get that error and status page. Here is what the User's manual says about print job storage:
"The printer supports two distinct job-storage features that you can use to initiate printing from the printer control panel after the print job is sent from the computer:
● Proof and hold jobs
● Private jobs
Make sure that you identify your jobs in the printer driver before printing. Using default names might override previous jobs that have the same default name or cause the job to be deleted.
The job-storage features require 48 MB of RAM. For printer models that have less than 48 MB of RAM, you can add memory so that they can support the features."
7/28/2018 7:08:53 AM • HP LaserJet 2420... • Answered on Jul 28, 2018
49.460E service error in HP Laser Jet 2420dn
This issue comes when your data proper transfer from your computer. 1 check data cable (USB or Lan cable)
1/10/2018 11:14:01 AM • HP LaserJet 2420... • Answered on Jan 10, 2018
2answers
On 3 different HP printers I get a printer error 49 when I attach printer to network
Printer driver corrupted or needs updateing
Goto www.hp.com and install printer update tool
9/27/2017 6:37:55 AM • HP LaserJet 2420... • Answered on Sep 27, 2017
2answers
My printer is giving an error message..."error
This is a Fan issue you have 2 of them one on the front right side and one on the left. if you remove both covers see which one is not working
Now if their are both working then you will need to replace the ECU (Engine Control Unit).
I've attached a link that shows you how to remove the covers off the 2420 it's a pdf file .
And the Left side cover will need to be removed to access the other fan.
5/10/2017 5:26:02 AM • HP LaserJet 2420... • Answered on May 10, 2017
Close top cover
Start by trying this.
Open the cover and look around for openings in the where the cover closes. In those openings there are interlock switches. 1 of 2 things have happened.
1, The switch may have become dislodged.
2. Look on the cover you have opened for actuators, ( pieces of plastic sticking out) that would go into those holes to turn the switch on when closed. Those often break off.
One of those 2 items is your problem, The switch is just not being actuated properly.
Make sure nothing is binding the cover also.
3/2/2017 9:44:06 AM • HP LaserJet 2420... • Answered on Mar 02, 2017
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
12/11/2016 1:07:39 PM • HP LaserJet 2420... • Answered on Dec 11, 2016
2420 printer printing very squiggly as if you are looking at a reflection in water that has currents in the water, this is not a toner issue
Looks like you have a clogged/possibly damaged heads and head alignment issues. Do the alignment procedure and check the manufacturer support website or Google for the factory reset button combination of the printer. Cheers, Mike.
4/7/2016 5:20:53 PM • HP LaserJet 2420... • Answered on Apr 07, 2016
2answers
Error- 49.4C06
I had this error too, i had 32 MB ram in the printer i took it out and put in a 64 MB chip in and the error went away.
4/7/2016 5:05:23 PM • HP LaserJet 2420... • Answered on Apr 07, 2016
Our printer is not printing correctly down one side, drags black ink, smears/burns it
Your toner cartridge is fubar.
2/19/2016 5:26:31 PM • HP LaserJet 2420... • Answered on Feb 19, 2016
10answers
Standard top bin full error in hp 5200 tn laserjet printer
i have hp 5200 printer
printer shows message top bin full
and not prints what slution of this error
2/3/2016 3:18:01 AM • HP LaserJet 2420... • Answered on Feb 03, 2016
HP LaserJet 2420 Printer Logo
592 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
error 49 4c06
  • Office Equipment & Supplies
