20 Most Recent
HP PSC 1610 All-In-One InkJet Printer Questions & Answers
Keep getting paper jam error
If your printer has a paper tray, do not fill the tray. Overfilling the paper tray is frequently causes paper jams. Many printers have sliding mechanisms that allow different types and sizes of paper to be fed into the printer. If the slider is not correctly positioned, it can cause a paper jam.
Can't finsh setup; it's stop
Uninstall the existing printer software.
Press Win+R to open RUN window. Type in %TEMP% and click on OK.
Press Win+R to open RUN windows. Type in PREFETCH click on OK.
Restart the PC.
Check for Windows Update , if found, install them and then restart the PC.
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
My hp 900 inkjet is
check the usb connections of your computer with your printer if connected well
go to my printer page on your computer and go to your installed printer then cancell all document sent to your printers
if problem persist check your printer if their is any paper jammed in your printer
im quite sure one of em mentioned above may br the issue
False paper jams--tried cleaning, reset, etc.
Have you tried this method? (listed below), if not, give it a try.
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
While they are drying, reset your printer; Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn of the main switch which the dc adapter plugged in. After keeping it Off for about 5 minutes, turn on again using only the power cord, and again leave it on for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges.
If there's not internal problem or wrong cartridges number, then your problem will be definitely fixed.
Good luck.
Thanks for using FixYa.
HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
