20 Most Recent HP LaserJet 2840 All-In-One Printer Questions & Answers
Not to sound like a smart aleck...do you have enough toner in it? Can you print a test page? Sounds like a toner issue to me.
HP LaserJet 2840... | Answered on Oct 20, 2019
printer is ok, check the connecting cable and drivers.
Hp laser Jet Pro P1606dn 52.0 scanner error
HP LaserJet 2840... | Answered on Dec 31, 2018
It's a problem with the scanner unable to "see" its home sensor. The home sensor is a black & white film strip stuck onto the flatbed glass, just above where the scanner head homes. The printer needs to "see" the two little black 1mm square bumps in the white area. When the scanner head "homes", as it just disappears under the plastic it should move left and right as it looks at the home strip. If it keeps going and chatters at the right-stop it didn't see the home strip.
This can be caused by dirty mirrors, or lens in the scanner head (clean them);
Low or off color light (replace the bulb or high voltage power board on bottom of scanner head);
Broken, cracked, or loose scanner head ribbon cable (replace or repair);
Dirty or crooked home sensor film strip (I had one of these: the black & white film strip stuck to the flatbed glass was slightly crooked, it doesn't take much!)
Dirty slide bar (clean & oil);
Bad stepper motor, bad scanner PCBA (replace).
HP LaserJet 2840... | Answered on Mar 02, 2018
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
HP LaserJet 2840... | Answered on Dec 05, 2017
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
HP LaserJet 2840... | Answered on Sep 22, 2017
Either a bad cartridge or your carousel is not synchronized properly. If you just replaced a cartridge that is likely the source of the error. You can find videos on YouTube on fixing the carousel issue.
HP LaserJet 2840... | Answered on May 19, 2016
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please take out the print cartridge
wait for the insert cartridge message to appear
unplug the power cord
wait for 2-3 minutes
plug the power cord back in
turn the unit on and reinsert the cartridiges
check for functionality
HP LaserJet 2840... | Answered on May 04, 2016
I suggest you download the HP toolbox according to your OS. This will give you a better understanding of the problem
You can get the link from the HP support website
HP LaserJet 2840... | Answered on Apr 13, 2016
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
HP LaserJet 2840... | Answered on Feb 16, 2016
You have a Carousal Alignment problem.
check this link.https://www.youtube.com/watch?v=xKwsYipQ0Ag
otherwise take it the your closest repair center. Good Luck
HP LaserJet 2840... | Answered on Dec 29, 2015
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
HP LaserJet 2840... | Answered on Dec 18, 2015
Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
HP LaserJet 2840... | Answered on Apr 30, 2015
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
HP LaserJet 2840... | Answered on Apr 27, 2015
it is scan camera error, it required service, the top scanner assembly open it inside the assembly there are 4 lanses with little dust clen properly as wll as convex lance, and the scan glass
and test it will work,
if it does not work it menes the service have not done or you have to replace this assembly
HP LaserJet 2840... | Answered on Apr 26, 2015
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
check yellow cartridge to see if toner seal tab has been pulled out
HP LaserJet 2840... | Answered on Mar 20, 2015
flatbed scanner needs replaced
HP LaserJet 2840... | Answered on Feb 24, 2015
HP LaserJet 2840 All-In-One Printer Logo
443 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laserjet 2840 just started printing
  • Office Equipment & Supplies
