20 Most Recent
HP PSC 2210 All-In-One InkJet Printer Questions & Answers
HP 2410 Photosmart All in One Printer
the clicking sound is coming most likely from the printhead carriage, if you open the printer so you can see the cartridges, is the carriage stuck? trying to move to a direction and makeing the sound?
Printer making jerking noise.
Could be one of several problems.
First and simplest - open the hatch to expose the cartridge carriage. When it moves to "centre" pull the power cable or switch it off at power socket. Move the carriage to one side or other and look into the far left and right corners of the machine to see if there is any paper or other object crammed in there. If so - remove it and check the other side.
If that is clear, you will see a thin transparent strip that runs the width of the printer and passes behind the cartridge carriage. Carefully clean this both sides and full length with warm water and a couple of drops of detergent (NOT ALCOHOL please). Put it all back together, power it up, and try again. If the machine still makes a racket, it is probably an electronics fault or a faulty carriage belt motor. In which case, I suggest you cut losses and replace the machine.
Why won't it print red?
1. Remove the cartridges
2. you could be able to see into the cartridge slot of the printer, a little part with so many contacts
3. Take a tissue of paper and isopropyl alcohol
4. gently clean the contacts into the printer, and also on the cartridge.
5. reinsert the cartridge and do a test print, Tell me how it goes
ADCSFXworks Printing Center
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
HP Product Registration pop-up
This is caused by an entry in the Task Scheduler. To get rid of it, you need to be logged on with Administrator priveleges, then do the following:
1. Click Start, type the following in the search field and press enter: Task Scheduler
2. Cllick Continue to confirm permission.
3. Click Task Scheduler Library in the Left column.
4. Click on any of the following in the center column:
a. InternetService Offers (If your pop-up is regarding the internet)
b. Registration (If your pop-up is regarding registering your PC)
c. Service Plan (If your pop-up is regarding warrenty)
d. Extended Service (If your pop-up is regarding extended service plans)
BTW, notice that the idiot that programed these entries set them to trigger every 30 minutes, indefinatly.
Hope this helps.
Dave
When the scanner head on my hp 2210 reaches the home position over the motor the motor continues to run and causing the gears to slip. is there a limiter switch that tells the motor when to stop?
Open the printer wipe down and clean everything!
The cause of this is dust! there are no switches to let it know it has reached the end it is only based on detection of the edge of that silver tape that's underneath, the detection is obviously done by... scanning! it is the contrast that triggers it
Clean the scanner glass from both sides,
the scanner module face
the silver strip
the white scanner cover/lid (this might be the main issue as the lid turns colour from white to yellow after a while) if the cover is yellowed try placing paper inside when turning it on if it persists try other colours or materials and experiment with it.
and if you still couldnt resolve it then you have probably changed your main board with a low quality one! Let me know about this last part!
Cheers
HP PSC 2210 - Printer sais: In conversation
Hi Pascal,
This looks to me like if the "fax" portion of the All-in-One was engaged.
Please try unplugging the telephone cable at the back of the printer.
Turn the printer off and then remove the power cable.
Leave it like this fro 10 seconds.
Reconnect the power cable and turn the printer “on”.
The message should have disappeared.
Now reconnect you telephone cable.
This might have happened if the printer “answered” te phone line and fro some reason it didn’t hang up.
Cheers,
Ed
PS1: If this worked for you, please com back and grade my answer.
You can also access the manual here:
English: http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Dutch: http://h10032.www1.hp.com/ctg/Manual/c01176662.pdf
