Gene,There are a couple of "hidden" attachment points which hold down the top bezel and glass. You can see step-by-step photos on disassembly of the scan bed that will show right where they are at http://www.fatrcat.com/hp7100/scan_head.html
Go to paint create black,cyan,megenta & yellow images & print it, observe which colors are not printing,If back missed replace black cartrige, if any color missed out of remain three replace colour cartridge.There is no option to switch off the catridges & printer can recognise the faulty cartridge and it will show on displays. You can order cartridges online.
Hmmm, how long did you leave the battery out. One time I had to leave it out about 1 hour. That worked for me.
Worth a shot, also check to make sure that the carriage is in it's proper place. Open the maint. door like you are going to change the ink, check to make sure all seated properly, close cover and see if error goes away. Also try unpluggin from power and plug back in.
if it doesn't print anything, there is a problem with the ink cartridges, if it just prints extra blank pages, you need to verify the printer settings have the correct page settings, and that your word processor doesn't add extra pages to your documents.
Cleaning, unfortunately takes up a lot of ink. Check ink levels. If you need to, you may have to put new cartridges in every 100 or 120 pages or so depending on how colorful the documents are.
How much printing have you done with this printer?
The full-featured HP OfficeJet 7130 all-in-one offers photo printing, double-sided printing, an automatic document feeder (ADF), a fax, a scanner, a copier, and inputs for all of the current breeds of photo memory cards on the market today. At first blush, the machine's large footprint may seem overbearing--until you take into account just how much space you're saving by putting all of your technological eggs into one basket. Unfortunately, the 7130 isn'
Leaving inkjet printers alone for a long time generally results in the print heads getting clogged. Try cleaning them by following the steps on this page. If this does not work, you may need to replace them.
Hi, Thanks for writing to Fixya.com. Please first try to re-set the printer. And then turn on and off. Removing the black bulb cover and cleaning the mirrors) is the correct way to handle this. If the error message displays again, perform a power cycle
1. Turn the product off. 2. Unplug the power cord from the product. 3. Wait 30 seconds, and then connect the power cord to the product. 4. Turn the product on. 5. Make a color copy by pressing the Start Copy Color button on the control panel.
If the error message displays again, follow these steps to reset the product.
Step one: Perform a partial reset
1. Disconnect the power cord from the product. 2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons. 3. Try making a color copy by pressing the Start Copy Color button on the product control panel. * If the error message displays again, proceed to the next step to try a semi-full reset. Thank you for contacting Fixya and please accept the solution if it has helped you.
The printer is waiting for you to analyze the color calibration page that was just printed. The color patch number will be indicated after you follow the directions on that page. Put in that number and hit Enter.
Otherwise hit Cancel to exit the calibration menu.
