20 Most Recent
HP LaserJet 4345mfp Printer Questions & Answers
Downld file now
SEND RFU UPGRADE
ON
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
I've tried to reset the maintenance-kit counter
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Hp 4345
Check ADF unit (automatic document feeder) working condition.
For diagnoses : Insert few paper(ex:10papers) in ADF unit & do copying, if UR succeed in copying, ADF is working well.. If not check the fault.
HP M4345 facilitated with digital sending option., for configuring digital sending U need to create shared folder with fully permissions in system. Better visit hp site or google to know about how to create folder.. You can do multiple scanning once configuration completed successfully..for more info visit:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c02720194-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1409945500358.876444892.492883150
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
58.04 error
58.XX ERROR To continue turn off then on
A memory error has been detected.
58.4 = Engine power supply
Replace the Engine power supply assembly
(100-127 volt) is part number RM1-1041-000CN
(220-240 volt) is part number RM1-1042-000CN
49.4 C18
dear friend,
494 c18 error belongs to 3 reason
1- check ur print server Que may be any junk file will be there or error documents will be there.(if you are using windows 7 then it easy to solve}
2-- printer firmware problem- update your printer firmware latest,
3 - check your formatted board
Slow print come out with hp laserjet 4345 printer
dear friend,
for slow print many reasons:
1- check tray adjuster
2- check tray customs or standard lock( it will be right side tray lock)
3- check your printer driver
4- check printer firmware
5-check printer fuser
these are the reasons printer work slove
Error 13.33.00 hp 4345
13.33 = Paper jam inside top cover area. The paper didn't arrive at the paper-delivery sensor on time. This is usually due to worn out paper pick and feed rollers in the paper trays. Replace the rollers and you should be good. This error also occurs if your paper has a high moisture content, is the wrong kind of paper (too thick or too thin), or is loaded in the paper cassette incorrectly.
