20 Most Recent HP DeskJet 3820 InkJet Printer Questions & Answers
Green & orange lights both flashing? Ink OK
http://support.hp.com/hk-en/document/c01852851
4/30/2016 9:51:09 AM • HP DeskJet 3820... • Answered on Apr 30, 2016
Printer cartridge's cyan and yellow not printing
replace w/new ink and nozzle check , if test nozzle print ok , if the same happened , head cleaning , test print , all solor solid nothing gap or blank within the color , mean good , try to print variety color picture.
12/21/2011 10:55:07 PM • HP DeskJet 3820... • Answered on Dec 21, 2011
I have not used this
I would take a train to Nebraska, go in to the local restaraunt (don't worry, there is only 1 restaraunt in Nebraska) and buy a cow from Orville (the cook). Rent a car and drive home with the cow in the back seat. When you get home, put the printer in front of the cow and have the cow jump up and down on the printer. If the printer STILL doesn't work after that, buy a new printer.
12/21/2011 10:53:08 PM • HP DeskJet 3820... • Answered on Dec 21, 2011
Looking to replace HP 3820 printer with another
hi
first of all, try to stay aay from inkjet printers -- they cost too much to maintain, relative to the overall cost when you buy one. secondly, Windows 98 is no longer supported. My suggestion is to buy HP laserjet ,as toners last longer and the average cost to maintain per year , after the first two years is approximately $50-$200 , and then another two years before you have to maintain again. Spend $400-500 for laserjet and save in th end. http://h10010.www1.hp.com/wwpc/ca/en/sm/WF02a/18972-18972-3328059.html
Do the math and figure out the cartridge cost over 1 year for inkjet.
hope this helps
2/7/2011 8:05:42 PM • HP DeskJet 3820... • Answered on Feb 07, 2011
My printer is a HP Deskjet 3820. But since I
The first thing is to download the correct driver for your printer at
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75045&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20?»
Also, you can download the HP utility that will give you the ink status and troubleshooting tips.
Let me know if you have any questions. Thanks.
Please make sure to rate this solution.
1/17/2011 4:13:50 PM • HP DeskJet 3820... • Answered on Jan 17, 2011
The cartrdge cradle on my HP3820 is jammed. It's
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
11/17/2010 4:50:08 AM • HP DeskJet 3820... • Answered on Nov 17, 2010
2answers
I need to find the
Link provided below will help you in each and every aspect with your printer. In case your don't find the assistant program then you will be required to install it from the CD which came alongwith your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09352&lc=en&cc=us&product=88629&dlc=en
9/16/2010 9:31:30 AM • HP DeskJet 3820... • Answered on Sep 16, 2010
My power and resume lights
check if it is not jammed , or try update new driver software
7/23/2010 12:53:30 PM • HP DeskJet 3820... • Answered on Jul 23, 2010
I have lost my disk, how do I install my printer?
Giving you two links. One to know how to search for drivers online and the other on how to install drivers for devices. Please follow them and you will be a happier person in future.
Search for Drivers Online
Installing Devices on PCs and Laptops
5/17/2010 11:06:04 PM • HP DeskJet 3820... • Answered on May 17, 2010
What does the orange flashing light mean?
this normally is an error message saying printing did not complete. Mainly due to no paper in tray or a paper jam.
It may also mean you are low on Ink.
May need to consult your manual for any extra reasons for this. If you don't have a manual maybe you can get one from HP web site.
4/22/2010 5:51:03 PM • HP DeskJet 3820... • Answered on Apr 22, 2010
Not printing in colour
chage the tricolor ctg out also verify that color is selected in the print driver I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
3/31/2010 3:50:36 PM • HP DeskJet 3820... • Answered on Mar 31, 2010
My deskjet 3820 will not pick up the paper at all
i can send a link of your problem read it carefully and solve your problem.
thanks.
http://reviews.printcountry.com/HP_DeskJet_3820_Printer_10149.html
3/22/2010 5:06:35 AM • HP DeskJet 3820... • Answered on Mar 22, 2010
The top (ink) light is blinking, and the printer
I have same problem, but no solution.
1/30/2010 7:31:49 PM • HP DeskJet 3820... • Answered on Jan 30, 2010
2answers
I'm trying to get my hp deskjet 3820 driver
dear uninstall driver unplug printer ........
restart system install driver
and after restart plug your printer ...
but many setup say between setup plug in printer thn plug in ok.....
enjoy it ....
1/30/2010 6:17:03 PM • HP DeskJet 3820... • Answered on Jan 30, 2010
Remove tape from printer??
I don't understand your question.
Is this a brand new printer? If so there are strips of packing tape installed onto the printer to keep some parts from moving while is transit or storage.
If you are talking about packing tape, then the installation book that came with the printer will show you where they are.
Don
1/28/2010 5:39:20 PM • HP DeskJet 3820... • Answered on Jan 28, 2010
Hello. my deskjet 3820 can't be recogonized by the
make sure the usb cable is properly connected.and you install ed the driver correctly.for solving the issue,
right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the printer driver .
1/25/2010 10:27:41 AM • HP DeskJet 3820... • Answered on Jan 25, 2010
HP DeskJet 3820 InkJet Printer Logo
76 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
top tear drop shaped button mean
  • Office Equipment & Supplies
