20 Most Recent
HP LaserJet 1000 Printer Questions & Answers
HP-1110 printer scanner can't be
Follow these steps to remove previous HP drivers, and then install the new driver.
Step one: Remove previous HP drivers
Follow these steps to remove the current drivers.
Disconnect the USB cable from the HP product, if it is connected.
Click the Windows icon (
), and then click Devices and printers
Find the printer icon (
) representing your HP product, right-click it, and then click Remove device
Follow the on-screen instructions to remove the driver.
Repeat these steps to delete multiple instances of the same printer icon, and also for any fax icons for the product.
Reboot your computer.
When your new operating system is up and running, simply connect the USB
cable from the computer to the back of the HP product, and then press
the Power button (
) to turn it on.
Windows 7 detects the hardware and automatically installs the correct
driver. A notification lets you know when installation begins and when
it is complete. You do not have to download any software or insert the
product CD.
Hp laserjet 1000 prints blank pages
when you had to remove the toner cartridge from the machine did you blow the machine ? if so did you remove the laser unit from the machine ? if yes , then check the shutter of the laser unit if it is opening
How do i fix an incompatible ink cartridge
The HP laserjet 1000 takes either the C7115A or C7115X cartridge. The common name is a 15A or 15X. If you have anything else - forget it, it won't fit. If you have a new/refilled one that does not work properly - make sure you have removed the seal tape or return to supplier.
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Windows 7 driver
What is the problem with the windows 7 driver, does it not print or detect the printer. if it does not print, try to delete the driver and reload from the cd or from the hp.com website. if it does not detect the printer, try replacing the usb cable or let a technician look at the formatter board of the printer.
Mirror printing
A worn fuser will cause a mirror image or duplicate image to appear on the page. Fusing assemblies can be purchased alone or as part of a maintenance kit.
