20 Most Recent
HP LaserJet 8500 Color Printer Questions & Answers
How do i refill my HP M1005 MFP Laser Printer toner cartridge?
You should not refill the cartridge...they are a one time use only in any HP laser printer. To use a refilled or refurbished cartridge either voids your warranty, and if you have a printing defect as the result of not using HP-branded toner or an refurbished cartridge HP will not be able to do anything for you...I used to work for one of their call centers doing printer support, and this was a common theme.
There are many places that may advertise that they refill the cartridges with HP-approved toner, but that is far from true. In order to keep your printer functioning properly, even though it may cost more, it is in your best interest to only use new HP cartridges in your unit.
Printing color on heavy paper with my HP8500
hello
there is a spot or deap cut in fuser's teflon by which the inkseated them & next rotation it comes out & freease a spot on paper kindly check them & replace the fuser for better performance.
pls comment whether it works or not.......................regards jitendra
In a continuous cycle, my
Hello First of all dont use the reffil tooner & second one this type problem comes due to failure of any one tooner,& it can be clear only replacing all the tooners simultaniously one by one.
Try to do this if problem persists then write to me.
Findingmy printers ip address
The easy way to find printer address is to take the print of configuration page for that press down arrow button u will got all information of configuration including IP address of Printer
Doesnt print black
There should be 4 individual drum units for each color feeding the transfer roll. No black means no black drum rotation or transfer.
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look
for Print Spooler in the list
highlight Print Spooler,
Click on
STOP button then click on START
close the window and check if the
print queue is gone.
Alternate method,
Click STart
Click
RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window
type
NET STOP SPOOLER ( hit enter button )
Type
NET START
Repeat the Stop and START Command
4-5 times
End the Command with NET START SPOOLER
Open
Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
HP Color LaserJet 8500dn - Error Code 54.2
Even thought the cartridge clicked in normally, there is a problem with it. If you still have the old one, put it back in, if the error clears, you know the new toner is no good. If the flap doesn't lift or is binding it will stop the carousel from spinning, a 54.00.02 is a cyan toner error. If you have another toner you can try that also. I know they aren't cheap, but a lot of refurbished toners can do this out of the box.
