20 Most Recent
HP PSC 1610 All-In-One Printer, Scanner and Copier Questions & Answers
When i try to copy,
Make sure the access panel/bar at the back of the printer is fitted in properly.
If you have removed it to clear a jam, it may not be seated properly.
Try to see if perhaps some paper is stuck in the rollers, or maybe your rollers are sticky
Use correct weight of paper - it does not really like card stock that much.
Make sure Junior has not shoved a pencil into the printer tray, etc.
Let the panel know if you were able to clear the jam and how you did it.
HOW TO DOWNLOAD HP PSC1610 PRINTER SOFTWARE.
Not sure what you mean but the simple thing is to go to the HP website.
At the top of the page it says SUPPORTt & DRIVERS
Click on that and then navigate through the options until you find the PSC1610.
Select the download you need, wait for it to download then run it.
Simple as that.
Trying to reinstall HP PSC
Check in control panel->administrative tools->services
This will show all services, running or not, that are installed on your pc. You are looking for the one called "Print Spooler" double click on its entry in the list and set it to automatic if it isn't already.
Free download hp psc all-in-one 1610
Hello and Welcome to FixYa!
You can get the drivers for the Vendors site, all you have to do is to navigate to that page, from the link I've provided below, then choose your Operating system (
Like Windows XP,Vista..). A download page will appear, I'll prefer downloading the Driver+Software Package, if available.
If you are having problems/questions, don't forget to ask. We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Download Drivers
I have tried cleaning it...back rollers don't turn
This usually happens when the roller is covert with a lot of dust/dirt or lint or it is completely worn out. Clean the rollers and see,if that helps the problem to be get resolved. Unless, you need to replace the rollers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
How do i print with just a black and white
To print in black and white, follow these directions:
- Open the "File" menu on your browser toolbar.
- Select "Print."
- When the Print box opens, click the "Properties" button, near the top.
- Click on the "Colour" tab.
- Check the box next to "Print in ."
- Click "OK."
- Click "OK" again to print the black and white document.
Hp psc 1600 doesnt print with snow leopard
Hi! Then I believe that its gonna be a software issue. Try to download a firmware update via web. This will support the printer and computer. Once updated it may work. HOpe this helps and have a good one!
