20 Most Recent
HP PSC 1610 All-in-One Printer, Scanner, Copier Questions & Answers
My HP printer/copy/scaner makes a loud clunking noise when printing
Just unplug the power cord and remove the cartridge and clean it and also It require servicing open the cover and apply some lubricant oil on the steel rod inside in the printer on which print heads move ,that you can do with lubricant oil it will fix the problem otherwise show it service center.Have a nice day and do not forget to rate please...!
Receive the message "no scan options" when
browse through your printer installation cd and go to setup
folder, then to destinations folder, and then right-click on the
destinations.msi (microsoft installer package) and then click on repair.
hope that helps
or
have you tried uninstalling and reinstalling the software?
hope that helps. ciao.
I get a vertical black
The first step is to clean the glass in the scanner tray with a mild cleaner. If that does not correct the line, then you could try a Duster spay can (CRC Duster or Ativa Cleaning Duster, etc.) to try to blow on the arm that moves under the glass. Be careful as the can should be used in short spurts or it will get very cold and stop spaying or freeze something in the machine.
If still no luck, try to see if this site will properly guide you:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=390315&lc=en&jumpid=reg_R1002_USEN
Good luck..................Pete
I want to reversa an
If you would like to reverse an image--by reverse, I assume you mean flip horizontally--then you will need an image editor.
GIMP 2.0 is a powerful editor that you can get much more use from with t-shirt making. Download GIMP, select your image, right click and select flip horizontally.
Additionally, some operating systems will allow you to right click the image and select "flip horizontally" or "reverse".
