20 Most Recent
HP Pavilion ze2000 Notebook Questions & Answers
Laptop won.t start windows keeps saying that it is lookng for errors windows 8 hp
redux, 1 (old post mine)not told how w8 got on XP PC.?no clue there and does not belong on here.2005 PC CAME NEW WITH XP NOT W8Intel Pentium M or Intel Celeron M, NO!_Intel 855GME/ICH4-M Chipset (zero support on 855 !!!Intel ICH4-M South Bridge: zero support now. Intel ended it.w8 UP do no like OLD PC.the HDD this old is bad and will corrupt any OS you place there.there is no intel support. so MS can undo that fact.buy used 2010 and PC and RUN w10w8 installed on a good PC can be upgraded to w10 for free.
If hard drive fails do u lose all data
yes most times
but we move it to 2nd PC in USB dock and try.
using RECUVA (free) (saved some mine for a fact)
https://www.pcdied.com/HDD-SDD/recovery.html
imagine a newspaper
burned to ashes, no data there! then
now pretend only some pages or holes burn some, yes data but not all.
that is how HDD work, dead or 1/2 dead or fractions
even 1/2 of one fail gone.
if smart tests fail, on the drive run RECUVA on bad drive on 2nd good PC.
How to block pop ups?
If you are using IE which comes with your computer by default,follow the steps as below. I've attached a picture as a guide for you.
- Click on "Tools".
- Hover your mouse cursor over the "Pop-up Blocker"
- Click on "Turn On/Off Pop-up Blocker" option.
You may also click on the "Pop-up Blocker Settings" to set your "Pop-up Blocker" blocking level and you can also allow pop-ups from specific websites by adding them to the exclusions list.
Please ,how can i type a back slash symbol
if you can't find the backslash on your keyboard, you can always use the so called ASCII code. It sound complicate, but it is simple: press and hold the left ALT key and press one at a time the following digits form the NUMERICAL KEYBOARD: 0 9 2 . Now release the ALT key and the backslash appears.
There is a code like that for all characters and digits oin the keyboard
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Nemam zvuka na laptopu
Trazio sam gdje pise 32 bitna ili 64 bitna,ali niasm mogao nac.
Na kojem bi mijestu mogao nac?
Gateway laptop mx8715 having startup problems.
Is the PC starting up?
How old is your PC and has it been slowing down of late? How long does it usually start up?
You can have many start up programs running in which case you would need to disable some that aren't mandatory. (I can get you through this if this is the case)
It is, more likely, your hard-drive is failing as disks become corrupted and sectors start to fail. This is due to too much defragmentation, time and use. If this is the case, you have a few options depending on whether your PC starts up, but you should back up all information on a different PC, USB, etc just incase it is on its last breath.
Power problem
Look for a solution in the computer section of FIXYA.
USB Ports do not work
Remove the drivers then shut down your computer wait 30 secs then turn it on.Windows will reinstall the drivers.They may have become corrupted.If they still won't work try updating the drivers! You can try updating the drivers first and if that doesn't work ,do the remove and restart your computer!
To remove or un- install the drivers right click on "My Computer" and select properties.then device manager.Finf the usb ports and uninstall them then restart your computer! For more info go to the USB maufacture's website
Audio fro speaker jxd685 headphones
driver updates might help, hit start, type computer management, then go to device/drivers, find your driver, rightclick it and click update, disable then re-enable, restart and it should fix. if not... its a hardwae issure, like a soundcard replacement
HP Pavilion ze2000
right click on the desktop and choose Arrange Icons By >> Show Desktop icons
