20 Most Recent
HP Pavilion Ze4805us Notebook Questions & Answers
Pc running slow
c drive should be free of softwares ensure that. furthermore few clean up tips are
Firstly either press
the windows sign with R simultaneously or click the start button on the left
lowermost corner
Then a small window
opens up . in the window type any one of the below and press enter. Another
window opens up now single left click on any of the window contents and then
press ctrltab from your keyboard with "A" tab of the keyboard. This is a
shortcut to select everything in the window. Then delete all. Repeat the
process for all the links detailed below this will speeden up your pc
• %temp%
• Recent
• Prefetch
• Cookies
• temp
How do you make the screen brighter. The screen is
Hello Carmen, Hi, If the brightness control won't do much, looks like the LCD back lamp an/or the LCD inverter module is going bad. eventually you won't see anything on the screen. Make do of the screen for now, until the lamp/inverter fails or replaced in advance. make the most out of it. You need it serviced by a technician or the dealer.
My HP pavillion ze4805us system speed keeps
Most laptops vary teh speed of the porcessor as needed, as a power saving measure. Less speed uses less power.
When the laptop is idle it drops the speed and increases as more is needed.
My mother gave me a HP Pavilion ZE 4500. I push
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Key board controller not working
Try connecting an external USB keyboard.
If that does not work, then it's time to contact HP, and order a replacement motherboard, or to purchase a brand-new notebook, or, if the product is still under "warranty", to make a warranty claim, to get HP to fix it, at their cost.
Video problem. Pavilion ZE4805US laptop
Most likely it is either a bad lcd inverter, due to the fact that you have clear picture on an external monitor. The inverter reduces the voltage coming from the motherboard to a lower level in order to power the lcd and the backlight. If this goes bad then you either get a picture randomly, a dim picture, or no picture on the lcd.
No hard driver found
If your hard drive is dead, (no hard drive found), you're going to have to have a new one (hardware) installed before you can re-install the OS and drivers (software). I doubt that you'll be able to retrieve data from the dead hard drive short of herioc (and expensive) measures.
Sorry - hope you were backing-up your data frequently.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "Very Helpful" rating from everyone I help.
Thanks for using Fixya.com,
Jon
I bought a used HP Pavilion Ze4500 and do not know
Hello, Jessie.
There is a hidden Administrator account that is created when your operating system is installed. Access that account and add your own account.
1. Boot your computer and press F8 repeatedly
2. Access Safe Mode
3. Key in “Administrator” in Username, with no password.
4. Go to Control Panel, then User Accounts
5. Create your account.
Hope this helps
My hp pavillion ze4805us is giving me a system
insert the os disc in some cases systems come with a system recovery disc if this is not the case just insert what you have shutdow your system when your system boots press the del,f2,or whatever hotkey your system uses to enter the bios menu then while in bios go to boot devices or boot options and click start from cd and then press f10 to save and exit your system will ask yes no click yes then it should restart and a white text should appear saying boot from disc ? click any button when os finnally loads it will ask you to install or to repair ?click repair this searches your system finds out what it's lacking and reloads it .this should be it hope this helps good luck
