20 Most Recent Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Questions & Answers
Request a handle assembly diagram from Husqvarna.
Husqvarna 130bt... | Answered on Dec 08, 2017
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Husqvarna 130bt... | Answered on Nov 23, 2015
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Husqvarna 130bt... | Answered on Aug 13, 2014
Did you run it with the pure gas in the tank? If so, it's probably beyond repair of the average homeowner. If you did not run it put your mixed fuel in the tank, push the primer many times to force the oil/gas mix into the carb, and you should be good.
Husqvarna 130bt... | Answered on Aug 02, 2014
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
Husqvarna 130bt... | Answered on Apr 03, 2014
Are you getting spark on plug? Check to make sure wire is connected to plug, if still not starting. Is fuel getting to plug? Remove plug an see if its wet. If its wet it could be flooded. If not fuel lines are common on saws, tank in is a major problem it cracks an need replacing. Have you checked the on off switch? If it still wont start, carb is more than likely the problem. Remove it an get a rebuilt kit, they are cheap, carefully remove all parts clean out all orifices even small ones with a piece of brass or steel bristle from a brush, use carb cleaner to clean the parts, carefully put it all back together an it should start. That is about all there is.
Husqvarna 130bt... | Answered on Mar 26, 2014
How long has the gas been in the Blower?
If it was 10% Ethanol gas( lie most States sell at the gas pump) and it has been in the Blower for more than a few months, you probably have carburetor issues.
Husqvarna 130bt... | Answered on Dec 29, 2013
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Husqvarna 130bt... | Answered on Mar 02, 2013
chech the primer bulb for cracks
Husqvarna 130bt... | Answered on Aug 30, 2012
Make sure both the idlers and tensioner pulleys remain aligned, i.e. pulley bearings and tensioner arm aren't wore out.
Possibly one of the transaxle is moving out of place. Check mounting.
You might try raising both rear wheels of the ground and then see if belt throws.
Husqvarna Garden | Answered on Jan 15, 2020
most saw bars are interchangeable compare them before you install it...ok so go find yourself a chart then...good day to you
Husqvarna Garden | Answered on Jan 07, 2020
Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Logo
Popular Tags
16 questions posted
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
handle assembly
  • Garden
