20 Most Recent McCulloch 1967 Mac 1-10/2-10 Chainsaw Engines Manual Questions & Answers
4answers
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40 https://www.youtube.com/watch?v=skwugvObHtU Dec 1, 2013 - Uploaded by Alan Marshall McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24 https://www.youtube.com/watch?v=MgfmIezh65c Mar 13, 2010 - Uploaded by keepin'itcountry cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
7/2/2022 3:48:28 PM • McCulloch Garden • Answered on Jul 02, 2022
2answers
I need to find what the part number is for an ignition coil to suit a Mcculloch Pro Mac 1000 chainsaw and where i could source one.
any small engine repair shop---online search and enter make and model and part name
3/13/2022 12:36:19 PM • McCulloch Garden • Answered on Mar 13, 2022
McCulloch mt 250 lk curved shaft line trimmer wont engage on bottom of shaft,how do i strip down the shaft
undo the collars at each end of shaft and separate
2/2/2022 11:46:24 PM • McCulloch Garden • Answered on Feb 02, 2022
Mcculloch 280B gas blower has compression, fuel, ignition, won't start
Remove all fuel. Remove spark plug. Dry out the crankcase and cylinder by pulling the starter several times.
Reinstall spark plug. Remove air filter, hold throttle open and spray a short burst (~1sec) of starter fluid down throat of carburetor. Release throttle and promptly pull starter rope up to 5x.
If it fires and runs a few seconds then it is a fuel/carburetor problem.
If still no fire then more likely a spark or compression problem. Replace spark plug with new proper type and gap. Retry with starter fluid. If still no run then likely either a failed ignition module or poor compression/crankcase leak.
11/30/2021 2:26:19 PM • McCulloch Garden • Answered on Nov 30, 2021
Where can I get a trigger assembly for my McCulloch 250-14 electric chainsaw?
order from repair shop in your area or online search
9/18/2021 2:57:40 PM • McCulloch Garden • Answered on Sep 18, 2021
How many Safety switches are there on a McCulloch Hornet sit on mower?
Normally just on the seat, plus Brake Switch and PTO Switch. https://www.google.com/search?q=mcculloch+hornet+safety+switch ..
6/13/2021 6:07:00 PM • McCulloch Garden • Answered on Jun 13, 2021
2answers
Hi how do i tighten chain on mcculloch m4218 chainsaw
loosen nuts a little and turn screw to move bar - tightening chain
1/10/2020 3:40:18 PM • McCulloch Garden • Answered on Jan 10, 2020
How to relance fuel line on a 35cc #1635 mcculloch chain saw
Tools required: Allen wrench 7/16-inch socket driver Needle-nose pliers Approved fuel container Scissors Work gloves Wire coat hanger paper towels or shop rags approx. 30 minutes
  1. Drain the fuel tank
    Wear work gloves to protect your hands. In a well-ventilated area, remove the fuel cap and empty the fuel tank into an approved storage container. Open the fuel cap.
  2. 02.
    Remove the cylinder shield
    Using an Allen wrench, remove the screws that hold the cylinder shield to the engine. Lift off the shield. Remove the cylinder shield.
  3. 03.
    Disconnect the spark plug wire and remove the air filter
    Disconnect the wire from the spark plug. Pull the cover off the air filter housing and remove the filter. Disconnect the spark plug wire. Remove the air filter cover. Remove the air filter.
  4. 04.
    Remove the fuel filter
    Straighten a piece of coat hanger and bend a hook on the end. Feed it through the mouth of the tank and fish out the white cylindrical fuel filter. Cut the fuel line to remove the filter.
  5. 05.
    Remove the carburetor
    Using a 7/16-inch socket driver, remove the 2 mounting nuts that secure the carburetor to the engine. Pull the air filter housing off the carburetor. Pull the carburetor from the engine block, sliding it along the mounting studs. Be careful not to bend the throttle linkage or damage the gas lines
  6. Remove the mounting nuts. Remove the air filter housing. Pull the carburetor off the mounting studs.
  7. 06.
    Remove the old fuel lines
    Pull the fuel lines off the carburetor and primer bulb, using needle-nose pliers. Use needle-nose pliers to pull the fuel lines out of the gas tank. Tip: With some chainsaw models, you'll have to remove the screws from the primer bulb to detach the fuel lines. Pull the fuel lines off of the carburetor. Pull the fuel lines off of the primer bulb. Pull the fuel lines out of the gas tank.
  8. 07.
    Install the new fuel lines
    Use a pair of scissors to cut the new fuel lines at an angle to thread them into the tank. Push the large line about 1 inch into the tank. Push the small line far enough into the tank so that it can be grabbed through the mouth of the tank with needle-nose pliers. Pull the small line out the mouth of the tank. Cut the end square and install the fuel filter. Pull the line back in so the filter rests on the bottom of the tank. Trim the fuel lines and connect them to the carburetor
  9. .
  10. Cut the end of the new fuel lines at an angle. Fuel line cut at an angle.
  11. 08.
    Install the fuel filter
    Pull the small line out the mouth of the tank. Cut the end square and install the fuel filter. Pull the line back in so the filter rests on the bottom of the tank. Trim the fuel lines and connect them to the carburetor.
  12. 09.
    Reinstall the carburetor
    Slip the carburetor onto the mounting studs and push it into place. Position the air filter housing on the protruding studs. Replace the mounting nuts and tighten them to seal the gasket between the engine and the carburetor. Tip: Avoid crimping the fuel lines when re-installing the carburetor.
  13. 10.
    Reinstall the air filter cover and connect the spark plug
    Position the air filter in the housing and replace the cover. Reattach the spark plug wire.
  14. 11.
    Reinstall the cylinder shield
    Reinstall the cylinder shield on the chainsaw. Refill the fuel tank.
11/5/2019 8:43:04 AM • McCulloch Garden • Answered on Nov 05, 2019
How to replace fuel line on a mcculloch #ms1635 35cc chainsaw
Here in link you will find step by step with picture instruction on replacing fuel line. https://www.ereplacementparts.com/repair-center/article/23480/How_to_Replace_the_Fuel_Return_Line_on_a_Poulan_Chainsaw_(Model_P3314).html
10/30/2019 3:05:58 AM • McCulloch Garden • Answered on Oct 30, 2019
Have a mcculloch M3816 chainsaw and cannot figure out how the trigger mechanism activates the throttle in the handle
There is usally a rod that travels under handle to carb. Could be a cable if its a top line saw. If you are having problem with it take top of saw body apart and it should give you access.
8/19/2019 4:36:56 AM • McCulloch Garden • Answered on Aug 19, 2019
Hi I have a McCulloch Trimmac 241 Strimmer which was not running when I got it, I took the carburettor off and the throttle cable came off but I cant see where the end goes onto the carb end, Help Jim
Most machines will have a z bend in the end of the throttle wire, the outer cable will be anchored with a square block into the induction block, the z bend in the cable will then fit into a hole in the throttle spindle on the carb, there will only be one hole in the spindle the correct size for the cable.
7/9/2019 8:36:55 PM • McCulloch Garden • Answered on Jul 09, 2019
McCulloch mt210 strimmer idling to fast
Some carbs have obvious adjustments ("H" for high speed, "L" for low speed or idle. )
Some however are hidden. Heres a video showing how to find theses hidden adjustments.
https://youtu.be/tlsVcCdzaoA
6/12/2019 5:20:17 PM • McCulloch Garden • Answered on Jun 12, 2019
McCulloch 1967 Mac 1-10/2-10 Chainsaw Engines Manual Logo
2 questions posted
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
View Most Popular
McCulloch Garden
  • McCulloch Garden
Most Popular Question
mcculloch 280b gas blower compression
  • Garden
