20 Most Recent
Honda Gx270 9.0 Questions & Answers
No pressure build up from pump
looks like this is a small triplex pump.ensure the pump is acually turning over with the power unit and the love joy coupler is working properly and there is no stripped out key ways ect. was the hose jumping before the loss in presure? this could indicate a washed out in the intake or dischage valve. or debris hung up there in. check the pressure relief valve/unloader valve for proper function may be the pressurised water stream from the hose is by passing .repair /replace as required.
Honda gx270
Check that the gas cap vent is not blocked and is working properly for one thing. Also check the oil level most honda engines have a low oil shut down feature.
Honda mower model HRR2163VXA engage blade and it backward not engage
If your Honda mower model HRR2163VXA is not engaging the blade properly when you attempt to engage it, and it's moving backward instead, there could be a few potential causes for this issue. Here are some steps you can take to troubleshoot and address the problem:
- Safety Interlock System: Most modern lawn mowers, including Honda models, are equipped with safety interlock systems that prevent the blade from engaging while the mower is in reverse or the handle is not properly engaged. Make sure you are following the correct procedure for engaging the blade and that you are not inadvertently activating the safety mechanisms.
- Drive Control Lever Position: Check the position of the drive control lever or drive engagement lever on your mower. Ensure that it is in the proper position for mowing and not in a neutral or reverse position.
- Control Cable Adjustment: The control cables that operate the blade engagement and drive functions can sometimes become loose or misadjusted. Check the cables for proper tension and ensure they are connected securely to their respective control levers.
- Belt and Pulley Inspection: Inspect the belt that drives the blade engagement system for any signs of damage or wear. Additionally, check the pulleys and pulley mechanisms to ensure they are functioning properly.
- Blade Engagement Mechanism Inspection: Examine the blade engagement mechanism itself, including the engagement lever and associated components. Look for any signs of damage, wear, or misalignment that could be preventing proper engagement.
- Consult the Manual: Refer to the user manual for your Honda mower for specific instructions on troubleshooting and adjusting the blade engagement system. The manual may have diagrams and step-by-step instructions for resolving issues.
- Professional Assistance: If you're unable to identify and resolve the issue on your own, consider seeking assistance from a professional lawn mower technician. They will have experience with Honda mowers and can diagnose and repair any mechanical or electrical problems.
It's important to prioritize safety when working with lawn mowers. If you're unsure about any step or if the issue is not easily resolved, it's recommended to seek professional assistance to avoid potential injury or further damage to the equipment.
8/5/2023 10:23:41 AM •
Honda Garden
Answered
on Aug 05, 2023
Spark plug torque Honda GX390
A common setting is 20 to 30 Nm, (15 to 20ft/lbs). First fit the spark plug with your fingers until tight. This is to make sure the screw thread lines up correctly. Then using a socket and extension bar like a screwdriver tighten the spark plug again. Finally, using the torque wrench set to 21Nm (15 ft/lbs), slowly tighten the spark plug until it is just getting tight or the wrench clicks.
**DO NOT over-tighten the spark plug as stripping the screw thread can be an expensive mistake.**
12/18/2022 12:49:37 PM •
Honda Garden
Answered
on Dec 18, 2022
