20 Most Recent
Poulan Pro 25cc 2-Cycle Gas Blower BVM210VS Questions & Answers
My blower stops running and cord got stuck
Does it seem to be the cord holding the unit? Try to turn the blower in reverse. Disconnect the spark plug and use a screw driver to reverse the blower., If the starter pawls engaged for some reason and jammed the engine, this should free them. If not, there could be problems inside the engine.
How come no spark?
I would change the plug first and check to see if the coil is firing by grounding out the plug and see if there is fire. If not the ignition coil or unit maybe bad. Hope this helps.
Poulon pro bvm210vs will not start
This is back to basics, does it have a good spark when the engine is rotated with the plug out? if no replace the plug and try again if yes, does the plug get wet with fuel?if no replace the filter in the tank and try again, if yes is the plug soaked with fuel? if yes check the fuel inlet needle in the carb which maybe causing flooding, if no, is the spark occuring in the correct place, to check this remove the flywheel and check the key has not sheared, if the key is ok, it may be an air leak through a gasket or crank seal.
How do I remove the gas tank on a Poulan Pro PPBP30/30cc gas backpack blower?
To remove the gas tank on a Poulan Pro PPBP30/30cc gas backpack blower, follow these general steps:
1. Ensure the blower is turned off and cool before starting any maintenance.
2. Locate the gas tank on the blower. It is typically positioned near the engine.
3. Look for any screws or bolts securing the gas tank to the blower. Use the appropriate tools, such as a screwdriver or wrench, to remove them.
4. Once the screws or bolts are removed, gently lift the gas tank away from the blower. Be cautious not to spill any fuel.
5. If there are any fuel lines or connections attached to the tank, disconnect them carefully by loosening the clamps or fittings.
6. Once all connections are detached, the gas tank should be free to remove completely.
Please note that specific models may have slight variations in the removal process, so consulting the Poulan Pro PPBP30/30cc gas backpack blower's user manual for detailed instructions is recommended.
11/19/2023 12:08:03 PM •
Poulan Garden
Answered
on Nov 19, 2023
Why will my Poulan Pro PO16542LT riding mower only go forward and backwards when clutch is engaged but when clutch is released it stops moving?
It sounds like there may be an issue with the drive belt on your Poulan Pro PO16542LT riding mower. When you engage the clutch, the belt tightens and provides power to the wheels, allowing the mower to move forward or backward. When you release the clutch, the belt should become loose and the mower should stop moving.
If the belt is loose or damaged, it may not be providing enough power to the wheels when the clutch is engaged. This could cause the mower to move slowly or not at all. When you release the clutch, the belt may not be loose enough to completely disengage from the wheels, which could cause the mower to continue moving slowly or even stall.
To check the drive belt, you'll need to consult the owner's manual for your specific model of mower. The manual should provide instructions for inspecting and replacing the belt if necessary. Alternatively, you may want to take the mower to a professional for repairs if you're not comfortable working on it yourself.
