20 Most Recent McCulloch Chainsaw Chain Saw Parts Piston Mini Mac 110 120 130 140 30 35 Questions & Answers
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
McCulloch... | Answered on Feb 20, 2018
Contact us
User manuals McCulloch Service
I trust this information proves beneficial.
McCulloch... | Answered on Feb 19, 2018
loosen nuts a little and turn screw to move bar - tightening chain
McCulloch Garden | Answered on Jan 10, 2020
Request the information directly from McCulloch.
McCulloch Garden | Answered on Dec 24, 2019
Tools required:
Allen wrench
7/16-inch socket driver
Needle-nose pliers
Approved fuel container
Scissors
Work gloves
Wire coat hanger
paper towels or shop rags
approx. 30 minutes
  1. Drain the fuel tank
    Wear work gloves to protect your hands.
    In a well-ventilated area, remove the fuel cap and empty the fuel tank into an approved storage container.
    Open the fuel cap.
  2. 02.
    Remove the cylinder shield
    Using an Allen wrench, remove the screws that hold the cylinder shield to the engine. Lift off the shield.
    Remove the cylinder shield.
  3. 03.
    Disconnect the spark plug wire and remove the air filter
    Disconnect the wire from the spark plug. Pull the cover off the air filter housing and remove the filter.
    Disconnect the spark plug wire.
    Remove the air filter cover.
    Remove the air filter.
  4. 04.
    Remove the fuel filter
    Straighten a piece of coat hanger and bend a hook on the end. Feed it through the mouth of the tank and fish out the white cylindrical fuel filter. Cut the fuel line to remove the filter.
  5. 05.
    Remove the carburetor
    Using a 7/16-inch socket driver, remove the 2 mounting nuts that secure the carburetor to the engine.
    Pull the air filter housing off the carburetor.
    Pull the carburetor from the engine block, sliding it along the mounting studs. Be careful not to bend the throttle linkage or damage the gas lines
  6. Remove the mounting nuts. Remove the air filter housing.
    Pull the carburetor off the mounting studs.
  7. 06.
    Remove the old fuel lines
    Pull the fuel lines off the carburetor and primer bulb, using needle-nose pliers.
    Use needle-nose pliers to pull the fuel lines out of the gas tank.
    Tip: With some chainsaw models, you'll have to remove the screws from the primer bulb to detach the fuel lines.
    Pull the fuel lines off of the carburetor.
    Pull the fuel lines off of the primer bulb.
    Pull the fuel lines out of the gas tank.
  8. 07.
    Install the new fuel lines
    Use a pair of scissors to cut the new fuel lines at an angle to thread them into the tank. Push the large line about 1 inch into the tank.
    Push the small line far enough into the tank so that it can be grabbed through the mouth of the tank with needle-nose pliers.
    Pull the small line out the mouth of the tank. Cut the end square and install the fuel filter. Pull the line back in so the filter rests on the bottom of the tank. Trim the fuel lines and connect them to the carburetor
  9. .
  10. Cut the end of the new fuel lines at an angle. Fuel line cut at an angle.
  11. 08.
    Install the fuel filter
    Pull the small line out the mouth of the tank. Cut the end square and install the fuel filter. Pull the line back in so the filter rests on the bottom of the tank. Trim the fuel lines and connect them to the carburetor.
  12. 09.
    Reinstall the carburetor
    Slip the carburetor onto the mounting studs and push it into place. Position the air filter housing on the protruding studs.
    Replace the mounting nuts and tighten them to seal the gasket between the engine and the carburetor.
    Tip: Avoid crimping the fuel lines when re-installing the carburetor.
  13. 10.
    Reinstall the air filter cover and connect the spark plug
    Position the air filter in the housing and replace the cover. Reattach the spark plug wire.
  14. 11.
    Reinstall the cylinder shield
    Reinstall the cylinder shield on the chainsaw.
    Refill the fuel tank.
McCulloch Garden | Answered on Nov 05, 2019
Here in link you will find step by step with picture instruction on replacing fuel line.
https://www.ereplacementparts.com/repair-center/article/23480/How_to_Replace_the_Fuel_Return_Line_on_a_Poulan_Chainsaw_(Model_P3314).html
McCulloch Garden | Answered on Oct 30, 2019
There is usally a rod that travels under handle to carb. Could be a cable if its a top line saw. If you are having problem with it take top of saw body apart and it should give you access.
McCulloch Garden | Answered on Aug 19, 2019
Google (McCulloch)(model)(manual) without parens OR contact McCulloch directly with your request.
McCulloch Garden | Answered on Aug 13, 2019
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
McCulloch Garden | Answered on Jul 24, 2019
Most machines will have a z bend in the end of the throttle wire, the outer cable will be anchored with a square block into the induction block, the z bend in the cable will then fit into a hole in the throttle spindle on the carb, there will only be one hole in the spindle the correct size for the cable.
McCulloch Garden | Answered on Jul 09, 2019
Some carbs have obvious adjustments ("H" for high speed, "L" for low speed or idle. )
Some however are hidden. Heres a video showing how to find theses hidden adjustments.
https://youtu.be/tlsVcCdzaoA
McCulloch Garden | Answered on Jun 12, 2019
i don't know. please be careful. different oil used for air vs water cooled engines. if info not on engine near fuel filler, details should be in owner's manual or from boat engine retailer. also, new vs used motors may use different ratios.
McCulloch Garden | Answered on May 21, 2019
http://s30387.gridserver.com/partsDiagrams/McCulloch%20Late%20models.pdf
McCulloch Garden | Answered on May 16, 2019
McCulloch Chainsaw Chain Saw Parts Piston Mini Mac 110 120 130 140 30 35 Logo
Popular Tags
2 questions posted
Top McCulloch Garden Experts
roeb
John Trevino
Sheldon Dedek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
View Most Popular
McCulloch Garden
  • McCulloch Garden
Most Popular Question
points gap mac 130 chainsaw
  • Garden
