20 Most Recent LG LFX25974ST 24.7 cu. ft. French Door Refrigerator With Freezer Light Questions & Answers
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
LG LFX25974ST... | Answered on Jul 02, 2019
replace the icemaker timer . thanks .
LG LFX25974ST... | Answered on Mar 05, 2016
My problem was similar to yours and my lg refrigerator model number is: LMXS30776D/02, I followed the steps like you with no luck. I just fixed mine last night and it's a pleasure for me to share with you my experience.As I was trying to figure out what was wrong with my fridge, as I was shaking and lifting the left front door of my fridge I noticed that the error code E: 15 disappear on the display. As we open the door back and forth for normal use,the error E: 15 comes back again.From that,I realized something wrong with the left front door of the fridge. I ordered a new left door, It came in yesterday, I installed it last night and everything works beautifully in my fridge, no more code what so ever. as a result, if you are experiencing the same problem,most likely you need to think replacing the left door of the fridge.
Let me know if this help.
Thank you.
LG Refrigerators | Answered on Dec 03, 2019
Well unless its a solar powered ice dispenser and the sun has'nt set yet, you
LG Refrigerators | Answered on Oct 21, 2019
Check the line that goes from the water pipe to the back of the refrig. Someone may have used something they shouldn't have. The lines in the refrig won't break down like that.
LG Refrigerators | Answered on Oct 16, 2019
check to see if on if ok check water inlet or filter if all ok possible bad maker
LG Refrigerators | Answered on Oct 10, 2019
see if compressor is running if yes bad cooling unit or temp sensor if running
LG LFX25974ST 24.7 cu. ft. French Door Refrigerator With Freezer Light Logo
3 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
code er co keeps coming display panel
  • Refrigerators
