20 Most Recent Pentair 140315 Swimming Pool/spa Sand Filter Trc100c Questions & Answers
tip
Triton 2 tr60 sand filter tank
My tank on a tr60 with only 20psi is the max I get on pressure well guess what the bottom is cracked, no problem get a new one. Not at almost 900.00 so I thought about it and came up with this, wet vac sand out disconnect the tank from lines, unscrew in side line on the top, remove fingers from the bottom assembly, in screw that pipe now all you have is a tank with 2 fittings and a drain. Go buy same fiberglass repair kit and start sanding inside and outside (outside is very important to get the gel coat off) and apply your glass I used a sheet then on top of that I used a mat and another sheet that is inside, on outside I used mat then four sheets first pict is the crack before doing anything second is the finished product that cost me 8 hrs of time and 34.00 kit for fiberglass from Home Depot. (NOTE WARNING I WOULD NOT ATTEMPT THIS ON HIGHER PRESSURE TANKS)
http://i.fixya.netwrite_tip-rrbdisodbu3ix3ptcrwcvqfl-4-0.jpg
2answers
My Pentair Easy Touch system will come on randomly.
Sometimes its a simple Power Cycling that's needed. Fancy term for going to the outdoor pool panel, flipping all the breakers to off, counting to 10, then turning them back on again. Hope this helps
3/13/2023 10:43:36 PM • Pentair Pool &... • Answered on Mar 13, 2023
My Pentair Intelliflo control panel is frozen I push buttons and nothing changes on the screen
What does the LCD Screen say? Does it say display not active?
12/29/2022 5:38:01 AM • Pentair Pool &... • Answered on Dec 29, 2022
Pentair master 400 controller will not respond to touch
Do you have an Easy Touch Controller?
12/29/2022 5:33:38 AM • Pentair Pool &... • Answered on Dec 29, 2022
2answers
Pentair spa and pool control
Yes, the water must be circulating rapidly when the heater is on from being cold. Once hot, it can just circulate gently.
12/29/2022 5:29:46 AM • Pentair Pool &... • Answered on Dec 29, 2022
Incorrect temperature reading on Pentair Mastertemp 400 pool heater
Sometimes it is best to call in the professionals who have the knowledge and tools to find problems.
11/3/2022 12:57:16 AM • Pentair Pool &... • Answered on Nov 03, 2022
Pentair Mastertemp 250 occasionally gets error E05.
stack flue sensor heater overheated check gas pressure if ok sounds like occasionally low pressure if pressure ok check for burner tubes blocked
9/25/2022 4:59:43 AM • Pentair Pool &... • Answered on Sep 25, 2022
My Pentair Easy touch wireless remote is receiving data from the outdoor panel but i can't turn anything on or off with it. Any suggestions?
Usually resetting the 'Service' breaker on the main control box resolves this. If not, even though your remote receives data, you may still want to replace batteries in the remote. Next would be a faulty remote transceiver board ( cheaper to replace than the next item), in the unit with the antenna, or the mother board (the more expensive item).
8/18/2022 4:48:07 PM • Pentair Pool &... • Answered on Aug 18, 2022
2answers
Pentair legend II pool cleaner,
From your description that is bad service Go online and google Pentair legend II pool cleaner hose swivels
8/6/2022 3:59:22 AM • Pentair Pool &... • Answered on Aug 06, 2022
Pentair Mastertemp 250 heater that turns on, but shuts off after about 30 minutes
make sure gas pressure is correct if too low it will overheat or possible blocked burner tubes
8/6/2022 3:57:06 AM • Pentair Pool &... • Answered on Aug 06, 2022
Can you have check valves when you have a intelliflo vs+svrs pump 011017 ?
no country told (down under?) parts and manuals and things vary all over earth. well they did not lie to you, as it would damage the pump.\ but I see you are reading the wrong manual.. learn that systems of many kinds vary by model or submodel or version even not known by you. some even vary by build dates. or from upgrades ask them only or bad things can happen. Pentair Intelliflo Variable Speed Energy Efficient Pump VS+SVRS 3.2kW 3HP Max 230V swimming pool or spa? or what? not told, (all of it) nobody knows what you have there, for sure huge pools., all piping valves etc. why not call for a real service tech>? if down under ask them (Australia)???? not told https://www.pentairpool.com.au/en/185/Home/Products/Pumps/Filtration-Pumps/-/intelliflo-vs-6 this manual contradicts you , per page 2 3:Use a check valve in the discharge line when using this pump for any application where there is significant height (head) to the plumbing after the pump. 4.Be sure to install check valves when plumbing in parallel with another pump. This helps prevent reverse rotation of the impeller and motor.<<< damage. not told the application, wow, gee some pumps are below grade of pool, and is called HEAD, and with any far distance up, the check valve keeps the pool for draining to the pump area during service. (the same true on suction side a pump down to a deep well losing prime. NO APPLICATION TOLD at all no real answers possible blind
7/30/2022 12:55:44 PM • Pentair Pool &... • Answered on Jul 30, 2022
2answers
Pentair VS Pump - Error Code 0021
Try this. Hold down the 1 button and the plus and minus button at the same time for about 5 seconds. You should see all the lights light up and the screen will go into reboot and display the model and whatnot. After that see if it comes on by pressing start
7/7/2022 2:09:55 PM • Pentair Pool &... • Answered on Jul 07, 2022
2answers
Pentair pool heater keeps tripping breaker when i turn on
When you switch it on, watch the breaker trip. Does it slowly move to off? That is a lazy breaker and needs replacing. People use breakers as switches and they are not made for that, so they wear out. If the breaker snaps straight to off, you have a short to earth. Look for water around the electrics particularly at the pump. If you can't see anything obvious, call out a pool electrician to diagnose and fix. There are other ideas on the link. https://www.google.com/search?q=pentair+pool+heater+trips+breaker ..
6/9/2022 2:19:14 AM • Pentair Pool &... • Answered on Jun 09, 2022
Pentair Mastertemp 125 clicking sound when trying to start. Doesn't start and just keeps clicking.
check to see if gas is on if ok check ignitor at start up
5/26/2022 6:39:53 AM • Pentair Pool &... • Answered on May 26, 2022
2answers
Pentair Max-e-therm troubleshooting!?
If you're getting a service system light with the pump on full and good water pressure out of the jets, then you might have a problem with the pressure switch in the heater.
5/22/2022 5:21:41 AM • Pentair Pool &... • Answered on May 22, 2022
Pentair 140315 Swimming Pool/spa Sand Filter Trc100c Logo
1 questions posted
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Pentair Pool & Spa
  • Pentair Pool & Spa
Most Popular Question
incorrect temperature reading pentair
  • Pool & Spa
