20 Most Recent
Miele Super Novotronic W1986 Front Load Washer Questions & Answers
About Miele novotronec washer
w
Here is the part number for the seal 6816000 As far as the trick, depending on your level of skill, there will be a tab on the seal itself and that should be positioned at 12 o'clock. You press the seal firmly onto the drum until you hear a pop. The clamping ring which holds the seal on is 8 mm bulb which reusable. The seal has to be stretch over the outer metal casing.
The digital timer skips 9 minutes out of the wash
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
