20 Most Recent Stihl Fs45 Trimmer Drum Sprocket 45 55 46 Questions & Answers
No, I'm not sure why STIHL even makes curved shaft trimmers at all. I have never worked on ine in 10 years of being a STIHL tech, I just throw them out when they don't work and steer the customer to a straight-shaft. It's their punishment for the mistake of buying the curved shaft in the first place.
Stihl Fs45... | Answered on Nov 23, 2013
Chec utube or buya clymer manual ...gottools
Stihl Garden | Answered on Jan 13, 2020
make sure your air gap from the coil to the flywheel magnet is .010. if it is then take the ground wire off the coil and see if you have spark then. if you do then your ground wire is grounding out somewhere. process of elimination form the coil to the switch.
Stihl Garden | Answered on Dec 28, 2019
Possibly fuel tank not venting properly. See recall.
https://www.stihlusa.com/information/recalls/toolless-fuel-cap/km130r/
Stihl Garden | Answered on Dec 14, 2019
Numerous women question how they could shrink fibroids naturally in the estimate to either steer clear of surgery or to fibroids home treatment cozy by themselves.
Stihl Garden | Answered on Dec 05, 2019
SORRY YOU HAVE TO DO THE SEARCHING FOR YOURSELF WE KNOW OF NOTHING LIKE WHAT YOU ASK BUT USUALLY HAVE TO DRILL THE BROKEN BOLT OUT I WOULD USE LEFT HAND DRILL BIT .WWW.HARBORFREIGHT.COM SELLS THEM
Stihl Garden | Answered on Dec 04, 2019
Set the gap between coil and flywheel to 0.010 inches, if possible disconnect the stop wire from coil to eliminate that part of the circuit. If spark, reconnect stop wire and check again with stop switch in the on position, should still have spark. If not there is a short in the stop circuit.
Stihl Garden | Answered on Oct 31, 2019
According to Stihl's engine service manuals, when the engine has no spark or a dramatic, sudden loss in power, the problem could lie in the ignition system. The ignition system ignites the fuel in the engine for proper combustion. When the spark isn't firing correctly, an influx of gas can bog the engine down or cause it to not start at all. Since you are dealing with potentially lethal high voltage, extreme caution is advised and safety gear should be worn at all times.
first Slide the rubber spark plug connector off of the spark plug. On most Stihl's this can be accessed from the top of the engine, underneath the chain brake handle. Unscrew the air filter cover and remove it, if you can't see it on top of the engine
then Insert the socket wrench onto the spark plug and remove it from the engine. Discard the old spark plug and replace it with a new, identical spark plug, which will be recommended in your operator's manual. Make sure the spark plug is gapped according to your manual's specifications or else the engine won't start.
after that Turn the ignition switch to the "On" position. Insert the spark plug into the rubber connector. Make sure the chain brake is disengaged by pulling back on the black chain brake handle, which runs atop the saw's engine.
Hold the rubber plug and spark plug, with gloved hands, about 1 to 2 centimeters from a metal point on the engine block. Wipe any flammable gas or oil from the metal spot on the engine with the rag. Tug on the starter cord and look for a blue spark across the "hex" part of the spark plug,Check to be sure the wires leading to the "On-Off" switch aren't tangled or touching a metal point on the engine if there is no spark, Replace any wires if they are damaged or corroded
Stihl Garden | Answered on Oct 30, 2019
Check the ground wire on your coil and see if it is loose or well grounded...
Stihl Garden | Answered on Oct 29, 2019
check with STIHL DEALER
Stihl Garden | Answered on Oct 23, 2019
start by removing the chain and cleaning all the dirt from there where the oil port is
80 MLS of 2 stroke oil to one gallon of fuel and it doesn't matter what octane, of course the higher octane is better cause it burns cleaner. To much oil will gum up your carburetor and engine.
Stihl Garden | Answered on Oct 07, 2019
i CAN ONLY GUESS THAT THE VALVES ARE STUCK CLOSED
Stihl Garden | Answered on Oct 01, 2019
Stihl Fs45 Trimmer Drum Sprocket 45 55 46 Logo
2 questions posted
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
View Most Popular
Stihl Garden
  • Stihl Garden
Most Popular Question
replacing trottle trigger stihl fs 45
  • Garden
