20 Most Recent Blue Wave Sandman Above Ground Sand Filter System Questions & Answers
2answers
After five minutes of vac the discharge turns orange why
your filter has removed the rust from the water backwash and use a filter cleaner when vacuuming a lot of rust off bottom or algae vac to waste so it doesnt go through your filter
7/12/2021 5:58:41 PM • Blue Wave... • Answered on Jul 12, 2021
2answers
What setting do I putmy pump on to vacuum sand out of my pool. I have the sandman 22"?
I'm not familiar with that particular brand, but if you want to get sand out of your pool you should first make sure you're ready to vacuum (with the plate firmly in the skimmer box and connected to your hose and then to your pole with the vacuum head), then turn the multi-port valve (MPV) to 'waste'. If your equipment is below the water line then water may start to come out your waste line - not a drama. Next, just turn the pump on and you will be vacuuming sand straight through the pump and out to wherever your waste line goes. Be careful to ensure that you don't let the waterline in the pool get below the level of the skimmer box, because if you start to suck air you increase the likelihood of damaging your pump. A good idea is to top up the pool as much as you can with a hose before you start vacuuming, and then top it up again as necessary as your going along. If you do need to top up the pool, be sure to get your water tested as soon as you can afterward, then top it up with whatever chemicals you may need.
9/29/2014 10:25:15 PM • Blue Wave... • Answered on Sep 29, 2014
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows: chlorine 1.0 - 3.0 ideal ph 7.4 alkalinity 100 ppm calcium 200 ppm stabilizer 50 ppm (saltwater pool 25 ppm) These values will provide balanced swimming pool water
8/12/2014 7:06:15 PM • Blue Wave... • Answered on Aug 12, 2014
2answers
Words have worn off the dial on the pump
These may vary somewhat. Google your filter model and search images. There should be some good pictures of the valve to compare with.
7/10/2014 12:45:23 AM • Blue Wave... • Answered on Jul 10, 2014
Have a sandman filter and having problems with dirt piles in pool. I brush and sweep vacum nothing is helping. Pump runs good water is clear as a bell. Please tell me what I can do to get rid of thes
Sounds to me that if the piles are right off of the return that one or more of the filter laterals has failed and needs to be replaced. Another possible problem is that its time to change the sand in it especially if it is 4 to 5 years old. At that age the contamiiate level is very high increasing volume in the filter.
6/8/2014 3:36:20 PM • Blue Wave... • Answered on Jun 08, 2014
I have a Sandman Sand filter and water is clear but have what looks like dirt piles in pool. I brush and vacum to no end and still have these dirt piles. I need to know what to do about this please he
Have you back flushed your filter? That will help in the cleaning ability of it, you will lose some water because you are flushing out the nasty stuff to the outside of the pool and filter. Try that and see if its better
6/8/2014 12:24:32 AM • Blue Wave... • Answered on Jun 08, 2014
I need to replace the drain fitting. Where can I get parts for a NE6170?
I am having the same problem any luck?
5/28/2014 3:03:16 AM • Blue Wave... • Answered on May 28, 2014
Filter has clean hoses and new sand, but water return is still low. valve cover has debris in non-removable housing.
Does not sound like a product failure. But more info would help so I'm making some assumptions. Double check the hose connections going into the filter are in the proper location. The hose from the pump will plug into the highest port and the return to the pool will be the lower port that does not have the sight glass. Make sure you are only vac'ing on the "filter" or "waste" setting. Never vacuum your pool on "backwash". If this is not your problem then look to the pump for an impeller blockage. Lining the pump basket with a nylon stocking will keep debris like cottonwood from making it through the basket and clogging impellers and filters.
4/12/2014 8:16:46 PM • Blue Wave... • Answered on Apr 12, 2014
My pool filter wont stop backwashing it is in filter cycle it wont stop even when i shut the pump off it still drains
Underneath your backwash valve handle is a gasket that looks like a wagon wheel. This has worn out and needs to be replaced. Your pool store may have one or you may have to get one from the manufacturer.
5/30/2013 11:53:43 PM • Blue Wave... • Answered on May 30, 2013
My favorite color.
Are you asking what your favorite color is? That's something you would know better than anyone else.
7/17/2017 7:22:08 AM • Blue Wave Pool &... • Answered on Jul 17, 2017
I have a blue wave inflatable spa. the ground fault blows when I turn the heater on. Is it possible to replace the heater element? If so, where can i purchase the part?
MarkI am not familiar with the Blue Wave inflatable spa however the ones we sell are replaceable so I would imagine that the Blue Wave one would be.Rodwww.uspartscenter.com
2/1/2013 4:50:39 PM • Blue Wave Pool &... • Answered on Feb 01, 2013
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered 2 days ago
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
My Maax 461 Spa Heater heats constant until overheat and trips out until manually reset. If jets not turned on, the heater will overheat and trip. Acts like contacts stuck?
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need. That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on. Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard. https://www.google.com/search?q=Maax+461+Heater ..
3/17/2024 4:08:41 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM • Pool & Spa • Answered on Mar 17, 2024
Blue Wave Sandman Above Ground Sand Filter System Logo
Popular Tags
16 questions posted
Top Blue Wave Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Blue Wave Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Blue Wave Pool & Spa
Most Popular Question
filter clean hoses new sand but water
  • Pool & Spa
