20 Most Recent
IBM wheelwriter5 - Wheelwriter 5 Electric Typewriter Grade C Questions & Answers
The return key does not work and even with a new ribbon the text does not show up on the paper.
Imagine your fingers are spread out and the have letters on them, a small electromagnetic hamer smacks the backside of your finger pushing it into ribbon and paper this makes a letter. What is occurring is the hamer is fireing between your fingers and hit the space between them, no letter is formed. Check your daisy whell or change it, the return key most likely has a cracked solder joint where it is conncected to the circuit board, if you can get the cass of I could probably talk you though the procedure but that's pushing it if you've never used a soldering iron, good luck,Bret
