20 Most Recent
IBM Lexmark Personal Wheelwriter 2 Electric Typewriter 6781-018 Questions & Answers
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Why ribbon feeder not functioning well.
I didn't know of anyone using one of these yet. I would say it is probably dirt, like dust in the drive gear or if it has a belt a loose belt could be causing the problem. A good cleaning with compressed air like the ones used on computers may solve your problem. Hope this helps you. Viking.
Repeat typing
Your machine does not have any memory to repeat what you have typed.
What would make my carriage not move?
If you mean the flat wire connector it is probably damaged or not properly connected. you need a tech. I'm sure we can repair it we are in Cleveland. Ohio.
DickyO
216-269-3918
