My hp wireless keyboard and mouse doesnt work
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
