20 Most Recent
HP Multimedia Cordless Keyboard/Mouse P5304A#ABA Questions & Answers
My keyboard do not work at all.A little rain water
You probably need a new one. What probably happened when the rain water got on it was it might have hit an essential component that was on that side. Like the power cord maybe it short circuited the power cord and the thing doesn't work without power.
Cpu not working, flashes red
are you using a usb port for mouse and key board??? you might have to change the drivers or find update, you changs drivers thru control panel ,look for usb hubs by scrolling down and you should a plus sign next to your mouse and keybord, clik on this and it will expand and show you your drivers, it will ask if you want to update, or roll back driversor,,, search,,,,if you don't like the options , just remove mouse and keyboard drivers and then reinstall or get new drivers from manufactors website and install them,
How to set hp cordless
go to control panel.......mouse.....buttons tab.....check box for button swap.....should do it.....Meder's tv
Thank you for using FiXya and rate please.
Letters coming off keyboard
Can't help you much. Suggest you either learn touch-typing or maybe get little white stick-on letters.
var fctb_tool=null;
function FCTB_Init_a3855d1bf0c4466b98949379cae0685c(t)
fctb_tool=t;
start(fctb_tool);
var fctb_tool=null;
function FCTB_Init_c4fce50ced7a4e61840aa3099f0fb9cb(t)
fctb_tool=t;
start(fctb_tool);
A few moments ago my
Usually you just need to press it again to pair them up again, also try a re boot
When typing some letters and spacebar will not
Hi, it sounds like the rubber behind the space bar is weak or stuck and in both case you have to replace the entire keyboard because it's not worth fixing it compared to the price of a new one.
Take care
Spilt wine on keyboard. Left arrow keys are not
hi..
this circuit board might have damaged because of wetness. try to dry up the board and clean it throught wil proper soft cloth and try using the keys.
if the problem stil presists then the circuit board is damaged so please change the keyboard
if my answer was usefull please vote me
Cannot use right side numbers of the keyboard, other functions ar
I'm not sure what keyboard you have but there should be an "Fn mode", "Mode" or similar button on your keyboard, it should be the same color as the function icons on your other keys. This is usually used to toggle between the different modes. If this doesn't work or only works while your holding it down then you'll need to find the setting software for your keyboard. It's most likely in with your other programs or in Control Panel, some will put an icon in your task tray that you can double click or right click to access them.
