20 Most Recent HP iPAQ HX2415 Pocket PC Questions & Answers
3answers
How do I set up my pocket pc to use wifi both at home and when I am traveling
You can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). If it's not showing up, you can try to change your home wifi settings to accept both 802.11b standart and 802.11g standart. (Because your device only supports 802.11b standart). Steps of changing these settings of a wirless modem changes from manufacturer to manufacturer. I hope this helps.
12/8/2022 5:20:46 PM • HP iPAQ HX2415... • Answered on Dec 08, 2022
Hp IPAQ pocket PC 2003 Pro w/Outlook 2002. I was given this pocket PC and I have no earthly idea how to use it. I would like to copy the instruction manual please. It has wonderful features like excel
it is useless now, the world moved on, and ended this device. no support, HP will tell you the same. google can find 2002 MANUALS NOW GONE FOR EVER AT HP.COM MOST ARE DEAD NOW. FOR SURE BATTERY AND LCD DEAD.
4/29/2022 2:07:55 PM • HP iPAQ HX2415... • Answered on Apr 29, 2022
Trying to backup my 2415
its and old absolute PDA, nobody uses the it has no support now. 2004, 17 years old, you the last ,man standing with this in your hand? iDK go to HP.com lick. support forum community then ask them what to do, expect jeers, endless on any PDA from 2004. ask there not here, PDA post here are rare and even not answered .
12/23/2021 3:44:47 PM • HP iPAQ HX2415... • Answered on Dec 23, 2021
Cannot Sync with Vista
Try the following workaround and see if that helps.
For some users, the following workaround has been successful:
Connect your device, go to Device Manager (Computer > Properties).
Find the Portable Devices node; Locate the Windows Mobile device entry, choose to uninstall the driver. Reconnect your device and try again.
If the above doesn't solve the problem, read and follow instruction on how to fix the problem on the below link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=421420&prodTypeId=215348&objectID=c00595366
I hope the above helps.
Good luck.
2/16/2011 3:45:33 PM • HP iPAQ HX2415... • Answered on Feb 16, 2011
Is there a way to have a HP 2415 pda work and sync
yes try use on vista mobile center
1/6/2010 10:34:39 AM • HP iPAQ HX2415... • Answered on Jan 06, 2010
I'm running Vista and can't
Hi there
Please try the following here.
10/1/2009 3:42:57 PM • HP iPAQ HX2415... • Answered on Oct 01, 2009
3answers
I'm running Vista and I'm
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
10/1/2009 3:42:46 AM • HP iPAQ HX2415... • Answered on Oct 01, 2009
I have an HP hx2415
The expert gave me instructions (and informaiton about the "consequences" of) to do a hard reset.
3/24/2009 5:54:39 PM • HP iPAQ HX2415... • Answered on Mar 24, 2009
Loaded with programs I dont use and need to know how to delete
To remove unused programs go to Remove Programs
(start -> settings, system tab)
3/19/2009 1:03:08 AM • HP iPAQ HX2415... • Answered on Mar 19, 2009
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
4. The Pocket PC resets and powers on.
3/19/2009 12:52:08 AM • HP iPAQ HX2415... • Answered on Mar 19, 2009
Blinking Green Ligh
Yes, this blinking green light is an appointment notification. So if you set up an appointment for September 30th, 2005 at 9:00 AM with a reminder set to 1 day....then on Sept 29th at 9:00AM, the IPAQ will turn itself on and a reminder screen will appear on your IPAQ. After a length of time (the default of which I can't remember now) the Ipaq will turn itself off, but will leave that green light flashing. When you then turn the IPAQ back on, the reminder screen will again appear and you can choose to dismiss the reminder or snooze it.
2/19/2009 5:30:23 AM • HP iPAQ HX2415... • Answered on Feb 19, 2009
BLANK LIT-UP SCREEN
Can I ask, did you have any problems with the company, elaptoprepair.com?
I have read things and i wanted to make sure this was a real company with solid service and not a scam. I have read some people complaining that they did not get their laptops back and there were double charges on credit cards. I just want to know if you found this to be true and what your experience with this company was.
Alex Van Name
[email protected]
310-295-8915
11/28/2008 8:59:06 PM • HP iPAQ HX2415... • Answered on Nov 28, 2008
2answers
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
3/29/2007 1:12:21 PM • HP iPAQ HX2415... • Answered on Mar 29, 2007
2answers
Send/Receive Mail with iPAQ
Did you select your account from the Accounts menu?
3/29/2007 1:04:13 PM • HP iPAQ HX2415... • Answered on Mar 29, 2007
My Wireless in the iPAQ hx2415 doesn't work anymore
Hi man. Yes you should first upgrade/reinstall the ROM. That includes your firmware, OS and drivers. Go to HP's web site and download these uprgades. Here's a dirrect link. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=443063&prodTypeId=215348&prodSeriesId=421399&swLang=8&taskId=135&swEnvOID=2067 Select your OS from the list first. Follow the instructions that come with these files. If after this it still doesn't work please let me know.
1/30/2007 4:33:30 PM • HP iPAQ HX2415... • Answered on Jan 30, 2007
HP iPAQ HX2415 Pocket PC Logo
33 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq hx 2415 will not go past ipaq
  • Computers & Internet
