20 Most Recent HP iPAQ H1945 Pocket PC Questions & Answers
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
HP iPAQ H1945... | Answered on Aug 25, 2017
HP , drivers , and updates are complex. (as are all OS)
the file must match your OS and version.
match your pC (exact IPAQ in this case)
and installed in the correct order.
pretend its a phone, best for any thing this old , it has no real value.
why not ask first before doing any updates
why did you, ?
was there some problems, yes then ask.
if there is a problem of any kind this is the first stop.
its free to ask for help. try that. please.
http://h30434.www3.hp.com/
HP iPAQ H1945... | Answered on May 09, 2017
check http://www.ipaqrepair.co.uk - they've got a pdf you can download and print. It shows 11 steps needed to replace the battery - comes with well written descriptions of each step and illustrative pictures - and its free
HP iPAQ H1945... | Answered on May 18, 2014
Your PDA doesn't have a inbuilt modem or wifi, so you can't use the Internet without a modem card.
Here are the specifications of your iPAQ:
http://reviews.cnet.com/pdas/hp-ipaq-pocket-pc/4507-3127_7-30422067.html
HP iPAQ H1945... | Answered on Jan 14, 2011
best is you call your service provider for the internet settings ten once u get it save them and u are ready to go with the internet!!
reply and rate!!
HP iPAQ H1945... | Answered on Jul 15, 2010
Did you replace the back up battery and assume the little thing under the paper do not remove tag was a screw? I did and destroyed the little ceramic variable whatever it is, so my screen does the same thing. If anyone has a schematic, I'd love to know what I destroyed and if it is obtainable.
Ron L
HP iPAQ H1945... | Answered on Nov 04, 2009
Charge the dead battery with other good battery for a while first.
HP iPAQ H1945... | Answered on Oct 25, 2009
Hey,
all the documents for it are available at this hp site
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=425745&
I think you will find all you need there.
Let me know if you need anything else.
Thanks,
Ekse
HP iPAQ H1945... | Answered on May 19, 2009
Hello and sorry for the delay.
the h1945 series is a very intresting pda. I have seen all sorts of problems relating this one. There are some things you may want to try. Based on that knoledge I may be able to find what's rong with your unit.
First, check if the back cover fits tight on the back of the unit. It's important because on some ipaq models, there is a small micro-contact that doesn't allow the unit to power on if the back cover isn't attached. I'm not sure if the 1945 has one, it's been 2 years since i've last phisically repaired one of these, but you may look for one yourself. It's a small contact near one side of the back opening, check to see if it can be pressed. If you don't have anything like this just ignore this tip.
Second, leave the pda connected to the charger for about 6 hours. Even if it doesn't do anything. Then try to start the bootloader by pressing the 2 outer keys near the D pad (simillar to the hard reset procedure) then, while keeping those pressed, press the power button and in the same time press the soft reset button with your stylus. You must do this with your charger connected to the pda. It may be difficult to achieve in the first try. Just try to do this a few times and if the pda doesn't respond even now, please post back. Furthermore, if you need more info about these 2 tips please reply.
HP iPAQ H1945... | Answered on May 05, 2009
plug in the charger - then press the soft reset button with the stylus - let sit for about a day or so...:)
HP iPAQ H1945... | Answered on Mar 09, 2009
Are you displaying all categories. Does the second line of screen say 'All Contacts'?
HP iPAQ H1945... | Answered on Sep 11, 2005
On the opening screen of iPaq Backup there's a line, "File," where the backup's filename appears, and a little box with 3 dots. Tap that little box and you'll get a menu allowing you to set the location.
HP iPAQ H1945... | Answered on Sep 07, 2005
What model HP iPAQ?
HP iPAQ... | Answered on Oct 28, 2013
HP iPAQ H1945 Pocket PC Logo
24 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq 1940 losing programmes during main
  • Computers & Internet
