Canon ZR Video Cameras • Uploaded on Oct 07, 2013
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
75 questions posted
156 Questions
143 Questions
137 Questions
80 Questions
73 Questions
