20 Most Recent
Magic Chef CAV2000AWW Top Load Washer Questions & Answers
Magic Chef washing machine getting out of balance
it is a sign that the dampeners on the ends of the tub suspension or support rods have failed
A pack of 4 cost around $80.00 and with a technician doing the job can be done in 15 minutes
with you doing the job , around 1 hour unless you can get the spares people to explain how it is done
get the spares from the service agent spares
any unbalance gets out of control unless it is got under control very early and that is what these dampeners are designed to do and 4-5 years is the design life expectancy
Washer vibrates badly in spin cycle.
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For
replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Washer fills w/ water, but will not stop filling.
Level control valve is bad or line came off it or a hole in line. But it's likely the valve. It could be that you can adjust it and it will work at one level only. it has a screw where you can do that. Just take the panel off and you will see what I mean.
Ken
11/16/2012 10:41:13 PM •
Magic Chef...
Answered
on Nov 16, 2012
Washing machine wont turn on or do anything
Hi As I understand you, there does not seem to be anything wrong with the belt in spite of the burning smell. have you checked the fuses. Often there are small fuses that distribute the power to different parts of the machines, they are most often situated near or in the control panel. Check that.good luckKolbrun
Hot water does not come in, only cold water comes
There are no water inlet pumps on standard washers- the water, both for hot and cold, is fed in simply under 'mains' pressure.
(The following is pre-typed for hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
The machine wash but the spin not working. so the
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
