20 Most Recent Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Questions & Answers
2answers
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
1/20/2024 12:47:53 AM • Samsung... • Answered on Jan 20, 2024
2answers
How to turn off magicolor demo
Hello! can you solve your problem? i pushed up and down keys of the monitor at same time and the Magicolor Menu appear
1/20/2018 7:56:58 AM • Samsung... • Answered on Jan 20, 2018
Como sacar magiccolor demo
How to Turn Off MagicColor eHow Just reverse the directions at the link above, most want it off not on.
3/17/2017 7:02:54 PM • Samsung... • Answered on Mar 17, 2017
How to change the resolution
  • Native Resolution - 1280 x 1024 at 75 Hz
  • To change your screen resolution
  • Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  • Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  • Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
  • if not display come pls select esc button to revert resolution.(don't press Enter)
9/4/2016 7:25:13 AM • Samsung... • Answered on Sep 04, 2016
2answers
Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
10/10/2013 12:22:10 AM • Samsung... • Answered on Oct 10, 2013
Monitor not getting switched off
When you have strange functioning going on, first place to check will be the power supply.
http://s807.photobucket.com/albums/yy352/budm/Samsung%20730B/
Please post back what you find.
3/26/2013 3:54:30 AM • Samsung... • Answered on Mar 26, 2013
Problems with starting
Hello,This is a sure indication of a failure in the filter capacitors on the power supply board. Here is a link to an article about repairing that power board, it is used in the 930b and 720 models too.http://www.ccl-la.com/blog/index.php/samsung-930-and-720-series-repair/
10/12/2012 9:22:47 PM • Samsung... • Answered on Oct 12, 2012
SAMSUNG LCD NO DISPLAY
reset the picture settings back to default. No more flickering and no more black outs! Give it a try... perhaps it works for you thx
1/20/2012 6:39:08 AM • Samsung... • Answered on Jan 20, 2012
0answers
I dont have a clue
I don't think your LCD has internal speakers. Does it have a small 3.5mm jack with a speaker symbol (like a headphone jack)? I was looking at a review of your model and there was no speakers listed on the specs.
9/19/2011 4:09:37 PM • Samsung... • Answered on Sep 19, 2011
I am turn op pc
check for correct vga cable connection
7/18/2011 2:17:48 PM • Samsung... • Answered on Jul 18, 2011
Display only stays on for about a second.
Look for bad caps with domed tops, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20730B/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
6/25/2011 3:04:52 AM • Samsung... • Answered on Jun 25, 2011
My monitor was not
I encounterred that same problem before. I just changed the video card cause it was corrupted.
6/18/2011 1:58:50 AM • Samsung... • Answered on Jun 18, 2011
My samsung 730b monitor has gone dark. is there a
this is probably a fault with the internal power supply or the backlight inside of the monitor. in certain Samsung monitors the capacitors go bad in the power supply, these can be replaced by re-soldering identical ones to the power board, which is fairly easy to do if you know how to solder. if that isn't the problem, the back lights have gone bad, which is very dificuly and probably expensive to replace. However, the monitor could be fine and you could have just altered the brightness/contrast or some other settings in the menu on the monitor itself, you could try selecting the factory reset option if it has one. Another thing that could go wrong is if someone has messed with the display calibration settings on the computer itself (unlikely).
5/2/2011 3:24:54 AM • Samsung... • Answered on May 02, 2011
A friend of mine gave
Most likely a VGA cable or DVI cable. I would place my bets on a VGA cable (both ends are blue).
4/7/2011 10:16:15 PM • Samsung... • Answered on Apr 07, 2011
What size screw should I
Metric screw M4 0.7mm Pitch, the length will be depended on the thickness of the mounting plate, try HD or LOWE's.
Notes; watch out for the DC filter caps to go out in this monitor.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
3/4/2011 9:23:48 PM • Samsung... • Answered on Mar 04, 2011
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
83 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
screen says check signal cable check
  • Computers & Internet
