20 Most Recent
Samsung SC-D23 Mini DV Digital Camcorder Questions & Answers
When i open the compartment
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor. This will require disassembling the camera to repair and can usually be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Where is the connection for
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200312/20031211083545640_SCD23-USA_FRA.pdf
When i plug the camcorder into PC using USB cable,
You'll need to install a driver (on your PC) for the camcorder first .... for the PC to recognize the device. The driver is usually provided in the software CD that came with the camcorder. Or, you may try to search for it on Samsung's website or ask a Tech Support person where to get it.
Lost data from samsung memory pen
Hello, sorry to hear of your memory stick problem, I take it that you have used this one lots of times before yes? if not and it was indeed a new one it should have had a format done on it before use.
If it was not formatted the pics you put on it will be lost I am sad to say.
After working fine, suddenly now when the battery
the clicking noise if its
coming from the tape area then the tape is stuck in there and that is probably killing the power to the camera for
safety of the machine. I would take this into a camera shop for close examination on my findings. If however the clicking noise is
coming from another area the power relay would be the question then.
Its hard to tell over email what is the true issue but I hope my advice and findings to help.
please do click the accept button if you like my advice and help.
Thanks and have a good weekend Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Tape stuck in camcorder
The way I can get a tape unjammed on my Sony camera is to remove the
battery, plug the camera into the AC charger that is plugged into the
wall outlet. Then power the camera on, wait a few seconds. Then unplug
the charger from the outlet, wait a few more seconds (camera still in
"on" position) and then plug it back in. I have used this method at
least 3 times to get the camera to release the tape.
