20 Most Recent Microtek C593 15" Flat Panel LCD Monitor Questions & Answers
Speakers don't work on monitor
2/15/2011 6:07:27 AM • Microtek C593... • Answered on Feb 15, 2011
Audio problems
check speaker cable, may be the speaker cable not connected properly
2/15/2011 6:03:44 AM • Microtek C593... • Answered on Feb 15, 2011
I have a Microteck C593 flat screen and has been
Hello there! We can definitely fix this issue. It would be helpful to know what version of windows you are running, but it is not required. What you want to do is shut down the computer, get it to the point where it is all the way OFF. Go ahead and turn on the computer, and as it starts coming up, before you see the "Starting Windows" or similar screen, you need to PRESS F8 on the keyboard. To make sure you do it in time, as soon as you turn on the computer start pressing F8 on the keyboard, about once a second until it takes you to a BOOT OPTIONS screen where you have options like:
NORMAL MODE
LAST KNOWN GOOD CONFIGURATION
SAFE MODE
and others, not necessarily in that order, but something similar, you will definitely know when you get there. At this screen you need to use the keyboard arrow keys to move down to SAFE MODE and press ENTER on the keyboard. This will boot you up in safe mode. From this point, you need to RIGHT CLICK on My Computer (either on the desktop, or under the START button menu) and go to PROPERTIES. From there you should have a HARDWARE TAB, the second tab at the top usually. From there you should have a DEVICE MANAGER button. Click on that, it will pull up a list of hardware in your machine. We want to look for Display Adapters, and click the + sign next to it (on the left of Display Adapters) and it should drop down at least one option there. Click on whatever it is that dropped down, directly below and "attached" to display adapters. It will highlight the option. Now click REMOVE or DELETE, whatever button you have at the bottom. It will ask you to confirm that you want to remove the device. You do, so click YES. You should have only one option under display adapters, and now it should be gone. If you have more display adapters, remove them the same way, but DO NOT GO PAST DISPLAY ADAPTERS. We want to just remove any and all display adapters on the system. Now that it (or they) is gone, we can reboot the system. So click START, go to SHUTDOWN, and RESTART (I'm sure you're familiar with this) and let it restart normally. It will reboot into NORMAL MODE on it's own, so just let it boot up. Once in Windows it will detect your display adapter again and install it all by itself. When it's done it may ask you to reboot, go ahead and do that if it does. Now you can boot up the computer normally without problems! (This next part is only if it still looks strange to you when it boots up, if things are too large for example, otherwise IGNORE THIS NEXT PART IF YOU ARE SATISFIED) From there you can adjust the resolution (screen size basically) by right clicking anywhere on the desktop picture, as long as it's not on an icon, and go to PROPERTIES at the bottom. From there you can go to settings and change the resolution with the little slider bar and click ok. Now you should be good to go!
Please let me know if something doesn't make sense, or you can't find the things I talk about. If you do need to reply PLEASE include what version of Windows you are using (such as XP, Vista, or 7).
Thanks so much!
Tim
12/4/2010 11:33:48 PM • Microtek C593... • Answered on Dec 04, 2010
Cant get my internal speakers to work
It "does not have any" unless you have installed some and they dont work..in that case i cant tell you.
12/4/2010 10:56:24 PM • Microtek C593... • Answered on Dec 04, 2010
I AM SETTING UP A DESK TOP COMPUTER AND MY MONITOR
Go in safe mode (tap f8 while booting the pc) and set the resolution of your screen to a lower one. then reboot and you should have a working environment
10/20/2010 12:19:08 PM • Microtek C593... • Answered on Oct 20, 2010
Monitor will not display screen after turned off for a week
no data is getting to the monitor , check cable
7/5/2010 7:30:16 PM • Microtek C593... • Answered on Jul 05, 2010
A friend who went overseas gave me this type C593.
No sync could mean the computer is generating signal at a frequency that cannot be supported by the monitor. As soon as Windows starts to boot, press F8 to display the boot menu. One of the choices will be VGA mode. Select it, boot into Windows, then set your resolution/refresh low. Reboot into normal Windows mode. If you now get display, then set the resolution/frequency to your liking (as long as supported by your monitor).
6/7/2010 9:09:40 AM • Microtek C593... • Answered on Jun 07, 2010
How can I download free audio driver for microtek
Monitor does not need sound driver, just think of it as nothing more than powered PC speakers mounted inside monitor case. You need correct sound card driver in the PC to get sound.
Testing monitor speakers: use an MP3 player to feed to monitor audio line input (Green jack) using audio cable with mini stereo male phone jack at both ends (try Radio Shack) , set the volume on the monitor half way. If you get the sound OK, then the problem is in the PC setup.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
5/28/2010 10:22:32 PM • Microtek C593... • Answered on May 28, 2010
My microtek flat screen monitor goes black every 5
I assume that you have already try it on another PC with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
4/3/2010 3:14:25 AM • Microtek C593... • Answered on Apr 03, 2010
I plugged the wrong voltage cord into the monitor,
You may have shorted out the AC plug. You'll need to test it for continuity by using a voltmeter.
If it is shorted out, then you'll need to have the plug replaced.
1/21/2010 7:13:56 PM • Microtek C593... • Answered on Jan 21, 2010
Microtek c593 monitors. Out of Range
Your Minotor not support windows 7 frequincy or resulation.please open your computer safe mode, and set monitor frequincy only 60Hz. Resulation less area .Then solve your problem.
12/27/2009 1:35:11 PM • Microtek C593... • Answered on Dec 27, 2009
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
5/10/2009 5:51:18 PM • Microtek C593... • Answered on May 10, 2009
C593 Microtek
If it has speakers it wil have a female jack for you to connect the sound from your computer audio out(usually the green jack) to the monitor. It if does not have sound you can buty extenal speakers most places limke wal and k marts
4/28/2009 7:49:02 PM • Microtek C593... • Answered on Apr 28, 2009
"Out of Range" problem on Guitar Hero
I got the solution fokes ... go into C:\Documents and Settings\Administrator\Local Settings\Application Data\Aspyr\Guitar Hero III and modify AspyrConfig ( open with notepad ) and modify          <s id="Video.Width">1440</s>     <s id="Video.Height">900</s>
This is how worked to me...the idea came after many many tries to fix it... and it will sure work for you :)
11/9/2008 4:36:37 AM • Microtek C593... • Answered on Nov 09, 2008
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
7/10/2008 1:20:34 PM • Microtek C593... • Answered on Jul 10, 2008
Microtek C593 speakers
There are no speakers on that monitor. Those are 'dummy' holes.
There are no AUDIO IN jacks on the back either.
6/17/2008 7:21:00 PM • Microtek C593... • Answered on Jun 17, 2008
Microtek C593 15" Flat Panel LCD Monitor Logo
Popular Tags
30 questions posted
Top Microtek Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microtek Computers & Internet
Most Popular Question
microteck c593 flat screen
  • Computers & Internet
